SBS. Script for using sing-box on Asus routers with Merlin firmware.
Another update of my script for installing, configuring and running sing-box on Asus routers with Merlin firmware.
Updated 02/22/2026. Version v2.5.0
Changes:
1. Added support for up to four configs with support for two subscriptions. Including:
1) Added their settings to the 'sbs config' menu.
2) Redesigned the 'sbs config' menu structure.
3) When installing or updating the script to version 2.5.0, three more configs are added if they don't already exist. These are "config-2.json," "config-3.json," and "config-4.json.". Initially, templates with the corresponding names from the project's GitHub page will be downloaded and saved into these configs.
4) When updating the script to version 2.5.0, config.json will be renamed to config-1.json.
2. All configs (config-1.json, config-2.json, config-3.json, config-4.json, and sbs-conf) have been moved to the /opt/root/sing-box/configs directory.
3. Typos, errors, and bugs have been fixed.
You can see the Readme.txt and Changes.txt files on the script's github page https://github.com/Dr4tez/sing-box4asus
