Hi
I've read various online articles about how you can disable and enable USB ports from the command line in Linux.
Has anyone tried this on an AC68U ?
My CPU temp is around 83c I've plugged in a £5 USB fan and that reduced the temp to 58c.. So was wondering if it would be possible to write a script that ran via a crontab every 15 minutes and checked the CPU temp.
If its over 65 then enable the USB port the fan is in.
If its lower that 60 disable the USB port..
So turning the fan on and off as the CPU temp changes..
Any ideas if this is possible ?
