Server minecraft
Paxsat
How To Set Up a Minecraft Server on router?
file minecraft_server.jar
Inviato dal mio SM-G935F utilizzando Tapatalk
Even if it was possible why would you want to? Since when does minecraft use less than 150MB of RAM?
are you sure hes not aski g about how to set up a portforward for the server?
No problem server PC.. But the server is on line only whit PC on.
Of course
It's a bit of a resource issue - compute wise, the router might be fine, but running Java and storing stuff can be a problem, as the router is a bit resource constrained...
Folks have run Minecraft Server on Pi2/Pi3 - there's more than a few "how-to" articles on how to do that... check the google..
If you want to share the server to the public - well, there's a few articles on what ports/protocols need to be forwarded there.
Install OPTWARE-NG and java but
admin@RT-N66U:/tmp/mnt/Elements/optware-ng/minecraftSERVER# java -Dfile.encoding
=UTF8 -jar nukkit-1.0-SNAPSHOT.jar
/tmp/mnt/Elements/optware-ng/lib/jvm/openjdk8/jre/bin/java: '/tmp/libjansi-32-482602560465004055.so' is not an ELF executable for MIPS
10:19:56 [INFO] Loading nukkit.yml...
10:19:58 [INFO] Loading server properties...
10:19:59 [INFO] Selected English (eng) as the base language
10:19:59 [INFO] Starting Minecraft: PE server version v1.1.3
10:20:01 [INFO] Opening server on *:19132
10:20:01 [INFO] This server is running Nukkit version 1.0dev "èæ(Apple)æ´¾(Pie)" (API 1.0.0)
10:20:01 [INFO] Nukkit is distributed under the LGPL License
> java.lang.UnsatisfiedLinkError: no awt in java.library.path
        at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1867)
        at java.lang.Runtime.loadLibrary0(Runtime.java:870)
        at java.lang.System.loadLibrary(System.java:1122)
        at java.awt.Toolkit$3.run(Toolkit.java:1636)
        at java.awt.Toolkit$3.run(Toolkit.java:1634)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.awt.Toolkit.loadLibraries(Toolkit.java:1633)
        at java.awt.Toolkit.<clinit>(Toolkit.java:1668)
        at java.awt.Color.<clinit>(Color.java:275)
        at cn.nukkit.utils.DyeColor.<clinit>(DyeColor.java:6)
        at cn.nukkit.block.BlockTerracottaStained.getDyeColor(BlockTerracottaStained.java:66)
        at cn.nukkit.block.BlockTerracottaStained.getName(BlockTerracottaStained.java:28)
        at cn.nukkit.item.ItemBlock.<init>(ItemBlock.java:19)
        at cn.nukkit.item.Item.get(Item.java:1524)
        at cn.nukkit.item.Item.get(Item.java:1513)
        at cn.nukkit.item.Item.get(Item.java:1509)
        at cn.nukkit.item.Item.initCreativeItems(Item.java:852)
        at cn.nukkit.item.Item.init(Item.java:816)
        at cn.nukkit.Server.<init>(Server.java:369)
        at cn.nukkit.Nukkit.main(Nukkit.java:68)
10:20:13 [INFO] [BugReport] An error has been detected, creati
Install chroot Debian and java.. But java is version 6
Version 8 Kernel old.
