When trying to install via amtm:
"Skynet installation failed"
With the command line:
/usr/sbin/curl -s "https://raw.githubusercontent.com/Adamm00/IPSet_ASUS/master/firewall.sh" -o "/jffs/scripts/firewall" && chmod 755 /jffs/scripts/firewall && sh /jffs/scripts/firewall install
Nothing happens.
Trying
wget https://raw.githubusercontent.com/Adamm
It shows:
Resolving raw.githubusercontent.com... 0.0.0.0, ::
Connecting to raw.githubusercontent.com|0.0.0.0|:443... failed: Connection refused.
Connecting to raw.githubusercontent.com|::|:443... failed: Cannot assign requested address.
Retrying.
Here's the disk check:
Mar 26 22:40:20 amtm disk-check: Probing 'ext4' on device /dev/sda1
Mar 26 22:40:20 amtm disk-check: Running disk check v3.0, with command 'e2fsck -p' on /dev/sda1
Mar 26 22:40:20 amtm disk-check: Disk check done on /dev/sda1
Mar 26 22:40:20 hotplug: USB ext4 fs at /dev/sda1 mounted on /tmp/mnt/routerusb
Mar 26 22:40:20 usb: USB ext4 fs at /dev/sda1 mounted on /tmp/mnt/routerusb.
Mar 26 22:40:20 kernel: EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: user_xattr
Mar 26 22:40:20 custom_script: Running /jffs/scripts/post-mount (args: /tmp/mnt/routerusb)
Mar 26 22:40:21 kernel: Adding 2097148k swap on /tmp/mnt/routerusb/myswap.swp. Priority:-1 extents:6 across:2260988k
Mar 26 22:40:21 Diversion: Starting Entware and Diversion services on /tmp/mnt/routerusb
Would appreciate any advice! Thanks.
Nothing happens.
Trying
It shows:
Retrying.
