Skynet Skynet v8 - Router Firewall & Security Enhancements
I'm a die-hard Windows user, but there's surely a suitable tool for Mac users, etc. as well...
BACKUPMON does all this. One can completely wipe and restore should the need arise.
There is a massive Cloudflare outage this morning which might make you think that Skynet is blocking something that it shouldn't...
Yeah, can’t update Skynet here, I’m thinking there is some internet badness still going on.
Sorry guys, I found the mistake. Some space in the configuration file was the culprit.
Cloudflare outage is still affecting Github which will lead to 404 errors when trying to update. It is also the reason for the wireguard error someone previously posted.
Looking like we might be online now……
I find I have to manually update stats in the GUI with 8.0.5. Anyone else seeing this?
Stats update every 12 hours automatically, but this can also be triggered via the webui or running the stats command.
This is the first time I am experiencing an issue while updating to the latest release (previously upgraded from 7.6.5 to 8.0.0 to 8.0.1 to 8.0.2 to 8.0.3 to 8.0.4 successfully). I am only using the default settings and no additional block list. Also never rebooted the rooter since last official 3006.102.5 release:
View attachment 69011View attachment 69013View attachment 69015
Can you reproduce this reliably or was it a once off?
Thank you.
One more issue came up, when adding an IOT block to one of my devices I get the following error message:
ipset v7.6: Error in line 1: Syntax error: cannot parse comment: resolving to IPv4 address failed
[i] IOT Blocking List Cleared
[i] Saving Changes
After that the IOT Blocking is set to [Disable] and all of my previous blocked devices i had configured under Skynet 7.6.5 have been cleared.
I had to uninstall and reinstall after update 8.0, and several other times. When adding back IoT blocking, it broke my IP tables rules and required uninstalling and reinstalling. after trying a couple times, I’ve left IoT blocking disabled for the time being. Running 8.0.4
I am however able to use a custom banmalware list successfully again.
Thank you for all your efforts, @Adamm
Have you tried v8.0.5
I can reproduce it reliably (several times yesterday), it is still doing it this morning, and Skynet Statistics still works fine:
Is it reasonably safe to conclude that the "missing Skynet" issues post-reboot have been fully resolved with the current 8.0.5 release?
Any issues when used in conjunction with the AGH (Ad-Guard Home) script?
It survives a reboot.
I can't answer the AGH.
Still unable to update Skyhet from 8.0.4 to 8.0.5 today. I have also noticed the following:
1 - Skynet Statistics have in fact stopped working (does not update anymore since Nov 18 at 10:51:10) shortly after having try to update again Skynet on the same date.
2 - Looking in skynet-0.log (from System Log), I have noticed that on Nov 17 starting at 10:00:00 the following unusual message showing for the first time in the log after having updated from 8.0.3 to 8.0.4
then
and then, repeating the same message every one hour starting at 12:00:00 up to now (excepted to the exact date/time I have retry to update to 8.0.5
I will wait two more days before removing then re-installing Skynet completely unless notified by you othewise (should you need additional imformation/check).
Since there was an improvement in lock handling in 8.0.5, you may as well reinstall now and see if the problem returns. My 2 cents…
Thanks,
I was aware of that but still want to give Adamm a chance to try some kind of test/troubleshooting (for his own benefit).
