Smart Sync dropbox stuck on initial
brettule
I tried to sync my USB HDD to my dropbox account but I was getting the "sync disk unplug!" error so I factory reset my router and kicked off the dropbox sync again. It now is stuck on "initial" and verifying. Does anyone know how to get dropbox sync to work?
I flashed the ASUS firmware back and Dropbox sync works fine. Factory reset, flash latest Merlin and retried dropbox sync and it's no good. Seems to be Merlins dropbox sync isn't working.
You are comparing two different versions. To compare with Asus's latest code, you must run 380.67.
