kurayami88
Need help trying to use SSH on asus router STOCK FIRMWARE since my router is not supported by Merlin (TUF AX3000).
I would like to disable the UPNP secure mode. but i only manage to get 1/2 way done...
these are the steps i managed...
1) windows powershell AS admin
2) ssh username@router_ip_address
3) cd /etc/upnp
4) vi config
5) \**edit file**
6) esc, then enter :wq
7) enter command :
> killall miniupnpd
> miniupnpd -f /etc/upnp/config
however, it might appear this is not the proper settings file? as the asus logs throw a "it is advise to use network interface name instead of xxxxxx" which doesnt show up by default when you initial boot the router.
Also, these settings do not retain if you reboot the router... if the router is switched off / rebooted ... the secure mode is enabled by default again.
I scoured the internet and forums for some guidance on SSH editing but found little to no results ....
any help is much appreciated https://emojipedia.org/folded-hands/
3) cd /etc/upnp
4) vi config
5) \**edit file**
7) enter command :
> killall miniupnpd
