Static NAT configuration on Asus Merlin
Scheggiaimpazzita
Hello all,
For web development purposes I need to configure 4 static nat on my asus RT-AC88U. I din't find any menu about that and I'm only use to Cisco/Juniper/Check Point devices to do that and really not so much skilled on linux environment.
To be more explicative, I must configure something like this:
10.10.10.10 in 156.34.10.10
10.10.10.20 in 156.34.10.20
and so on.
Can anyone help?
Thanks in advance
octopus
Part of the Furniture
ColinTaylor
I suppose anything's possible if you're willing to reconfigure most of how the router works.
The main issue is that the whole firmware is designed around the premise of having a single WAN IP address (or 2 for dual-WAN), from which it can do a 1-to-many NAT.
Scheggiaimpazzita
Thanks all. After some hours of reading I finally found an IPTABLES configuration that works and is the following:
iptables -t nat -A INPUT -s <translated destination ip> -j SNAT --to-source=<original destination ip>
iptables -t nat -A OUTPUT -d <original destination ip> -j DNAT --to-destination=<translated destination ip>
iptables is powerful, not really easy to use but it can do almost anything.
