Things I want to be added
mizwdev
- something that allows me to do some LAN firewalling, like which mac or ip has WAN access
- bandwidth control with time schedules
- bind 2,4 and 5 Ghz wireless to one VLAN i.e. 501, which I maybe can push to AiMesh nodes, it is possible, cause I do it manual.
I wanted to win the lottery last night , it didn't happen.
Sticky Threads , Merlin.
Q: Will you add feature XYZ?
A: Chances are that no, since adding new features is a very low priority for this project ..................
Welcome to the 21st century.
For the first, they are there, they are called "Time Scheduling" and are in Parental Controls.
For the second point, you can write a script to turn QoS on and off regularly, which can meet your needs. Or you just turn on a guest network with bandwidth limiter and use it when you need it.
For the third point, this is what guest wifi 1 does.
