Entware Transmission stopped working
kman
Hi All, after the latest updates to entware packages, Mar 15, 2023, Transmission has stopped loading. I don't see anything in the sys log except the following:
Mar 16 22:58:39 admin: Failed to start transmission-daemon from .
Running it from command line, it also mentions failed.
admin@RT-AX86U-C280:/tmp/mnt/merlin/entware/etc/transmission# /opt/etc/init.d/S88transmission restart
 Starting transmission-daemon...              failed.
Any idea what could have caused this and how to resolve?
Thanks.
Running it directly I see the following:
admin@RT-AX86U-C280:/tmp/mnt/merlin/entware/bin# ./transmission-daemon
./transmission-daemon: error while loading shared libraries: libssl.so.1.1: wrong ELF class: ELFCLASS32
Try running the script with the debug flag. It might show some clues as to what the problem is and someone else can help you. I don't use Transmission so I can provide only initial troubleshooting steps.
Bash:
sh -x /opt/etc/init.d/S88transmission restart
Ah, it looks like the same problems related to the recent Entware packages upgrade.
Right, it appears to be the same issue but according to the suggestion, I need to re-install program.
The solution is to re-install program, which brings you the same version of program, but right relations between dependent files.
I've tried 'opkg install --force-reinstall transmission-daemon' but still error. Any ideas?
FIXED - at least a workaround. Per the other threads, I reinstalled libcurl and that worked.
opkg install --force-reinstall libcurl
Thought process - used 'whatdepends' to determine usage of libopenssl. From there, just reinstalled libcurl
admin@RT-AX86U-C280:/tmp/mnt/merlin/entware/etc/transmission# opkg whatdepends libopenssl
Root set:
  libopenssl
What depends on root set
        pixelserv-tls 2.4-2     depends on libopenssl
        libcurl 7.86.0-1        depends on libopenssl
        transmission-daemon 3.00-19     depends on libcurl
        transmission-web 3.00-19        depends on transmission-daemon
For next time, remember to shut down Transmission prior to updating packages.
EDIT: formatting and added context.
UPDATE: if encryption is enabled in Transmission, it's crashing. See log.
Mar 17 01:07:02 kernel: potentially unexpected fatal signal 11.
Mar 17 01:07:02 kernel: CPU: 2 PID: 13003 Comm: transmission-da Tainted: P           O    4.1.52 #2
Mar 17 01:07:02 kernel: Hardware name: Broadcom-v8A (DT)
Mar 17 01:07:02 kernel: task: ffffffc029cc4140 ti: ffffffc022d58000 task.ti: ffffffc022d58000
Mar 17 01:07:02 kernel: PC is at 0x7f7e40c9c4
Mar 17 01:07:02 kernel: LR is at 0x4175b4
Mar 17 01:07:02 kernel: pc : [<0000007f7e40c9c4>] lr : [<00000000004175b4>] pstate: 80000000
Mar 17 01:07:02 kernel: sp : 0000007f7df93fd0
Mar 17 01:07:02 kernel: x29: 0000007f7df93fd0 x28: 7fffffffffffffff
Mar 17 01:07:02 kernel: x27: 0000007f7804cf90 x26: 000000003eeadcf0
Mar 17 01:07:03 kernel: x25: 746f727020746e65 x24: 72726f5474694213
Mar 17 01:07:03 kernel: x23: 0000000000451e98 x22: 0000000000000000
Mar 17 01:07:03 kernel: x21: 0000000000453598 x20: 0000000000000014
Mar 17 01:07:03 kernel: x19: 0000000000000000 x18: 0000000000000000
Mar 17 01:07:03 kernel: x17: 000000000047a5e8 x16: 0000007f7e40c9b0
Mar 17 01:07:03 kernel: x15: 0000007f78000090 x14: 0000000000000013
Mar 17 01:07:03 transmission-daemon[13001]: tr_crypto_utils OpenSSL error: error:0308010C:digital envelope routines::unsupported (crypto-utils-openssl.c:189)
Mar 17 01:07:03 kernel: x13: 6e7c8ec8dedbd255 x12: b96b61c59469a7c4
Mar 17 01:07:03 kernel: x11: 0000000000000018 x10: 0101010101010101
Mar 17 01:07:03 kernel: x9 : cb7e726f0e2d840b x8 : 613b7cff3a2fd580
Mar 17 01:07:03 kernel: x7 : dedbd255b96b61c5 x6 : 0000007f7df94080
Mar 17 01:07:03 kernel: x5 : 0000000000000007 x4 : 0000000000000000
Mar 17 01:07:03 kernel: x3 : 0000000000000003 x2 : 0000007f780008d0
Mar 17 01:07:03 kernel: x1 : 0000000000000014 x0 : 0000000000000000
The only thing that has worked for me is to make sure that the Peer Listening port in the Transmission GUI is closed. If I allow it to be open it will crash every time.
This is transmission package with debian patch for openssl3 compatibility. Please test, if you need anther arch - report here.
can't load the GUI with the aarch64
404: Not Found​
Couldn't find Transmission's web interface files!
Users: to tell Transmission where to look, set the TRANSMISSION_WEB_HOME environment variable to the folder where the web interface's index.html is located.
Package Builders: to set a custom default at compile time, #define PACKAGE_DATA_DIR in libtransmission/platform.c or tweak tr_getClutchDir() by hand.
@zyxmon
Any clues for below warning ?
transmission-daemon[5433]: UDP Failed to set receive buffer: requested 4194304, got 1048576 (tr-udp.c:97)
It's fine, it was as long as I can remember. You may tweak net.core.rmem_max, net.core.wmem_max to avoid this warning. Or just ignore it.
The previous package version transmission-daemon_3.00-19a works! But there are reports it has memory leaks. Here is another one (based on gentoo patch) -
and
Do we install on top of previous 19a release or shall we uninstall 19a first ?
Can the memory tweak for net.core.rmem_max, net.core.wmem_max cause any memory issue to AX86 router if applied ?
