TUF ax5400 VS RT-ax82u
damasko
Hello, I am looking to understand which differences are between the tuf ax5400 and the ax82u.
On Asus specs I see that ax82u is 2x2 on 2.4ghz, while ax5400 is 4x4.
Any difference on chipset? On range? Others?
Thank you
These are very similar devices. I think the biggest difference is that the TUF segregates the 2.4 and 5 frequencies to separate antennas. Oh, and less RGB :)
