Upgrade - Backing up setting.
TomT
Hi
I'm going to be upgrading from 374.43_2 (Merlin build) to RT-AC68U_3.0.0.4_376.45_0
Do I need to backup my settings and can I restore them ?
At least back up all my 'Manually Assigned IP around the DHCP list' and Wifi access lists ?
Hi
Just directly flash.
I'll let Merlin double check me, but if you are using the jffs partition, I think you need to back that up first as there was a change there.
Hi
As far as I'm aware I'm not using it.
I bought the router flashed merlin and have not do anything since..
Apart from port forwarding rule, wifi Mac filtering and dhcp lists.
Hi Tom,
As stated by Merlin: You can simply upgrade from .43 to .45/.47 (lastet version) as the version do not have different hidden settings - no factory reset needed. :)
But to be prepared for the worst case (factory reset needed) you can backup the user settings to file on an usb drive via a small script.
After upgrade and factory reset in the new version, you can restore the save values with the other part of the two scripts. :rolleyes:
Below my examples on how to save (get) and restore (set) NVRAM values - again: do not forget to save the values (and scripts) onto a USB drive or copy them to your PC - otherwiese you will loose them... :(
After running the NVRAM set script you can check the values and if they are OK you need to execute a 'NVRAM commit' command to store the values permanently.
More details about the backup/restore script can be found here.
With kind regards
Joe :cool:
Example get NVRAM script:
#!/bin/sh
nvram get dhcp_staticlist > dhcp_staticlist.txt
nvram get wl_maclist_x > wl_maclist_x.txt
nvram get wl_maclist > wl_maclist.txt
nvram get wl0_maclist_x > wl0_maclist_x.txt
nvram get wl0_maclist > wl0_maclist.txt
nvram get wl1_maclist_x > wl1_maclist_x.txt
nvram get wl1_maclist > wl1_maclist.txt
Example set NVRAM script:
#!/bin/sh
nvram set dhcp_staticlist="`cat dhcp_staticlist.txt`"
nvram set wl_maclist_x="`cat wl_maclist_x.txt`"
nvram set wl_maclist="`cat wl_maclist.txt`"
nvram set wl0_maclist_x="`cat wl0_maclist_x.txt`"
nvram set wl0_maclist="`cat wl0_maclist.txt`"
nvram set wl1_maclist_x="`cat wl1_maclist_x.txt`"
nvram set wl1_maclist="`cat wl1_maclist.txt`"
bertilak Mesh firmware upgrade ASUS Wireless 0
