Upgrading RT86U to RT88U same configuration
joeejo
Is there any way to used the saved configuration from my RT-AC86U (Merlin 386.3.2) to install on a new RT-AC86U (Merlin 386.3.2)?
I am trying to avoid manually configuring the new router to my existing config.
Thank you
bbunge
Part of the Furniture
First off it is a router.
Next, the answer is no if you are going from an AC86U to an AC88U. Manual config is always best when changing hardware. And use a new SSID.
ColinTaylor
Your title says "RT86U to RT88U" but the post says "RT-AC86U to RT-AC86U". :confused:
rn170uk
Isn't that a downgrade? I have the AC88U but thinking of upgrading to the AC86U. Several posts here say the 86U is better. Am I wrong?
ColinTaylor
Yes the RT-AC88U would be a downgrade. It's a two year older model. The only advantage it has is the eight LAN ports.
L&LD
And for a few/many, ports 5-8 are not very stable.
rn170uk
I have that issue myself. Hence I've just bought and AC86U. The AX is stupid money 2.5x what I paid for the AC. Arriving tomorrow.
May try and RMA my 88U as I would expect it to last more than 12 months for the price it cost. Clearly I will factory reset / restore to Asus firmware first. They can only say no. If they replace it, I'll have one to sell on.
The annoying thing is I need > 4 ports so will need to run some more cables to my switch via ducting.
