I have an RT-AC87. My computer uses an Cisco IPsec VPN from one provider and my iPhone and iPad use IKEv2 from another provider. The clients are on the devices, I am not running the router based client/server. The reason for the dual providers is complicated and not really relevant to this question.
My question is that even with IPsec passthrough turned on in the router it seems like the router will not allow both of the VPN/s to pass through at the same time. If the computer is turned on first and then I turn on the iPhone it will either not connect, or it will connect but force the computers VPN to drop, or the other way around depending on which was powered up first.
Can two clients from different providers live behind the same router, or does everything have to be on the same VPN provider?
Thank you.
Thank you.
