I have a Lenovo AIO S730 desktop and an Acer A5 laptop both on a Virgin Media network, connected wirelessly to a Virgin Media Hub 3.0 (no VPN), as the main modem/router, and an Asus RT-AC68U as the second router. The Asus has Merlin firmware and has ExpressVPN installed using OpenVPN. I also have a Firestick 4K installed on the network
I have checked the settings and done leak test etc and all seem to be working correctly, as I get an IP somewhere in East London, some distance from where I live.
I have also set up two other locations around London which I can change to, if necessary.
Running on either router, without VPN, our two computers and the Firestick return speeds of around 220 to 240 MB/s
Running on the Asus, with the VPN active, the three devices return speeds of between 17 and 27 MB/s om all three VPN locations.
Is this VPN speed, around 10 times slower than no VPN as expected, or is there something wrong with the settings?
I would appreciate your help.
Thank you
Thank you
