Before I start down this path (I cannot wait for [open/dd]WRT support) - has anyone tried modifying the lan ports for more vlans? I know the switch in these supports 16.
I need to make the 5Ghz Radio on a separate network than the default LAN, and add it to one of the LAN ports like so:
#LAN
vlan1hwname=et0
vlan1ports=1 3 4 8*
#WAN
vlan2ports=0 8u
vlan2hwname=et0
#NEWLAN2
vlan3hwname=et0
vlan3ports=2 8*
This is where I do not know what to do:
lan_ifnames=vlan1 eth1 eth2 wl0.1 wl0.2 wl0.3
I assume the br0 is created from that list, but I now need a br1 - I can do all of this from the command line, but I just need to make sure my logic is sane before I mess with nvram. I can already modify the wl0.x, etc once it is running - I just want to make sure my logic is right for making the lan port a part of the VLAN properly, and if there is something I can do for a new lan_ifnames - (lan2_ifnames?) - that will allow the firmware to set this up automatically? I am only used to swconfig - this is my first broadcom proprietary router and I do not want to hose it, but I desparately need isolated networks (not the MAC filtered guest stuff they implemented).
Also if there is a binary (I cannot find it) like `swconfig` on the unit, that would make me able to control it on the fly and not just when the unit boots, then please tell!
I was bummed to see how they implemented guest networking to say the least..
TIA
-Greg
#LAN
vlan1hwname=et0
vlan1ports=1 3 4 8*
#WAN
vlan2ports=0 8u
vlan2hwname=et0
#NEWLAN2
vlan3hwname=et0
vlan3ports=2 8*
TIA
-Greg
