Need a nudge to finish this conversion. The TM-AC1900 now shows RT-AC68U and has firmware of 3.0.0.4.376_1703. I have the AMD NAND. All I want to do is turn this into a repeater. Do I flash firmware for ASUS or Merlin, if so, which version so the repeater function to show up on the GUI. Recovering from motor vehicle accident with diminished brain function unfortunately. Any help would be appreciated!
RT-AC68U login: admin
Password:
ASUSWRT RT-AC68U_3.0.0.4 Wed Jul 16 08:39:37 UTC 2014
admin@RT-AC68U:/tmp/home/root# dmesg | grep -e "flash" -e "nand" -e "amd" /tmp/syslog.log
Dec 31 16:00:16 kernel: Found a AMD NAND flash:
Dec 31 16:00:17 kernel: pflash: found no supported devices
Dec 31 16:00:17 kernel: bcmsflash: found no supported devices
Dec 31 16:00:17 kernel: lookup_nflash_rootfs_offset: offset = 0x200000
Dec 31 16:00:17 kernel: nflash: squash filesystem with lzma found at block 28
Dec 31 16:00:17 kernel: Creating 6 MTD partitions on "nflash":
Dec 31 16:00:17 kernel: Creating 2 MTD partitions on "brcmnand":
Dec 31 16:00:17 kernel: 0x000006000000-0x000007ec0000 : "brcmnand"
admin@RT-AC68U:/tmp/home/root# nvram get bl_version
1.0.1.6
admin@RT-AC68U:/tmp/home/root# nvram get boardrev
0x1100
admin@RT-AC68U:/tmp/home/root# nvram get HW_ver
170
Password:
1.0.1.6
0x1100
170
