What is the format of new dhcp_hostnames nvram variable in 384.13?
Db Major
Hi all,
What is the format of the new dhcp_hostnames nvram variable added in 384.13?
dhcp_staticlist format used to be <Mac>IP>Hostname and now the hostnames don't show up.
I'm guessing the new dhcp_hostnames variable means the new format of the dhcp_staticlist is now <Mac>IP
What is the format of the dhcp_hostnames variable?
I did guess <Mac>Hostname but that didn't seem to work.
Thanks in advance for your help.
For an RT-AC86U or AX88U, they’ll be in /jffs/nvram/dhcp_hostnames.
Thanks dave14305, that's exactly what I was looking for!
When one uses the nvram set dhcp_hostnames=<Mac>Hostname functionality, it doesn't actually update the file.
Something that may need checking.
Thanks again!
Thanks again!
I think it only migrates the nvram to jffs once on initial boot after upgrading. It won’t keep the two in sync.
