KarylFStein
I’m trying to make a wireless “hotspot” at home for visitors so I can give them some sort of login/key, (WPA2-RADIUS or SSL-directed captive portal software—haven’t gotten that far), to make it easy for them to get access to the Internet when on-site, but not internal machines. The hardware related to this is:
Netgear WNAP210 AP
Netgear GS716T Switch
Netgear FVS336G Router
Ubuntu Server
(I’m not a Netgear fanboy—it just turned out that way! I wanted dual-WAN with automated fail-over as my primary cable-based connection drops every once in a while and that’s bad for a home office so added a DSL backup along with the FVS336G, which works well there. I liked the idea of SSL VPN in the router, but that’s now handled by a WHS2011 server as SSL-VPN on the router didn’t work too well. I wanted PoE for the AP so I didn’t have to run power to place it in a central location in the house. Finally, I wanted a switch with VLAN capabilities to do something like this hotspot project. At the time of purchase, these seemed to be the best fit, but I am open to alternatives.)
The problem is I can’t get the hotspot working. Here’s what I did:
1) Set up two SSIDs on the WAP. One is WPA2-PSK tied to VLAN 1 and the other open access to VLAN 2 with the idea of RADIUS or captive portal for them in the future. (There’s a separate Dlink(!) G wireless AP with WPA2-AES for things like the Wii that don’t do N—channels appropriately spaced.)
2) Set up a VLAN interface on the Ubuntu server (eth0.2) for VLAN 2 and set up a DHCP server on that interface only to hand out addresses on a different subnet than the “internal” one.
3) Configured the router for “LAN Multi-Homing” so it’s also on the “hotspot” network.
4) Added a second VLAN to the switch and set the WAP and Ubuntu server as “tagged” on VLAN 1&2 with the router as “untagged” as it doesn’t handle VLANs.
It seems like I need to uncheck the “Unchecked VLAN” box on the WAP and it would work, but if I do that I lose access to it from the LAN and have to hard-reset it or nothing works.
Is what I’m trying to do feasible with the equipment at hand? It seems like it should, but I can’t get the “hotspot” wireless network operational…
Netgear WNAP210 AP
Ubuntu Server
