homeofwind
Using AX86U, switched ISP today and 5g gets full signal but 2.4g not even half of the speed (1g download but only getting 160m max). Tweeked the setting per the thread still slow. Any suggestions?
Thanks. Will read this long paper. Not sure: for 1G download internet, I am getting about 170m mx download while 5G gets full 1G. Is it normal?
I am testing it with a labtop with Wifi 6 with AX86U
170 mbit/s is very good speed from 2.4GHz.Thanks. Will read this long paper. Not sure: for 1G download internet, I am getting about 170m mx download while 5G gets full 1G. Is it normal?
Is it normal?
Is that so? Just about to call the ISP and have them check. bascially we are paying only for 5G speed for the 1g internet?170 mbit/s is very good speed from 2.4GHz.
Ok. Any suggestions I should set for the frequency channel? Anyone using 1G internet share of their speed for 2.4g? Curiouse to know.No. Normally you get about 90Mbps on 2.4GHz band with 2-stream client and 20MHz wide channel.
Curiouse to know.
This is the way.Read the long paper. You can't get any better than what the technology allows.
Welcome To SNBForums
