There are several more threads. For example:
Just weird. I can't understand how that file could fail to write. And why it's even empty. There's plenty of storage. It's clearly writing leases to that file given we see the attempt. Can you write anything else to that same storage? Try the following script. cat /var/lib/misc/temp.txt...
www.snbforums.com
For quite a while now, I've been struggling to correct an issue with my RT-AC88U, which seems to be getting worse. Any help is very much appreciated. Router: Asus RT-AC88U Firmware: 386.2_6 current 384.17_0 previous Modem: Motorola MB8600 Adapter: ASUS PCE AC88 Devices: Windows 10, Desktop PC...
www.snbforums.com
I raised a thread a week or so about problems I was having with my RT-AC86U, regarding really slow DNS responses, and also Fing complaining that DHCP wasn't always happy. @L&LD suggested I do a full wipe and reset, which I reluctantly did. The good news is that this seemed to solve the problems...
www.snbforums.com
As you can see, these kinds of issues go way back.
Personally, I'm extremely frustrated by this striking lack of QC. Bought an AC86U to run the internet in my apartment complex thinking this was a true and tested model like the AC68U.
After borrowing another AC86U unit, flashing back and forth both official and Merlin firmware two versions back, I'm getting constant micro-disconnections on devices with with medium-low signal strenght on 5ghz jumping back and forth between 2.4 and 5ghz - even on official firmware. On Merlin firmware it happens even with devices in the same room as the router. Sometimes it worsens to the point that you cannot stream a tv show without being interrupted every 10-15 minutes. Completely untenable and unacceptable.
Jan 25 17:01:30 wlceventd: wlceventd_proc_event(527): wl0.1: Auth 62:07.. [MAC-address], status: Successful (0), rssi:0
Jan 25 17:01:31 wlceventd: wlceventd_proc_event(527): wl0.1: Auth 62:07.. [MAC-address], status: Successful (0), rssi:0
Jan 25 17:01:32 wlceventd: wlceventd_proc_event(527): wl0.1: Auth 62:07.. [MAC-address], status: Successful (0), rssi:0
Jan 25 17:01:35 wlceventd: wlceventd_proc_event(508): wl1.1: Disassoc 62:07.. [MAC-address], status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jan 25 17:01:35 wlceventd: wlceventd_proc_event(527): wl1.1: Auth 62:07.. [MAC-address], status: Successful (0), rssi:0
Jan 25 17:01:35 wlceventd: wlceventd_proc_event(537): wl1.1: ReAssoc 62:07.. [MAC-address], status: Successful (0), rssi:0
Jan 25 17:01:35 wlceventd: wlceventd_proc_event(508): wl0.1: Disassoc 62:07.. [MAC-address], status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
... on and on in a reoccurring loop with 10-15 minutes between. Two Android-devices on the guest network seems to be the culprint atm, but with Merlin, it happens with all devices. Tried going back a few Merlin releases, but it caused wild CPU spikes and other issues.
(yes, I've tried to disable Smart Connect, 20mhz 2.4 band etc. Not that that should be necessary, that being said. And hard-resetting, yes). Merlin is even worse than the official firmware with respect to instability. Perhaps not his fault as I understand he is relying on proprietary blobs from Asus, but ffs the Merlin features is the reason I bought Asus in the first place.
Tenants complaining, countless hours searching forums and troubleshooting etc., bugs popping out of nowhere, no solution in sight. I'm not even running anything custom, just WPS-reset'ed stock settings. I'm so fed up with this POS I'm considering tossing out my whole fleet of Asus routers and never buy Asus again.
The AC68U works with no problem as a AiMesh node (I've also tried the AC86U without AC68U as an AiMesh node), but the AC86U (main, WAN connected) is reliably unreliable and basically unusable at this point. Even my AX88U on another location started throwing some of the same errors after the recent 386.4 upgrade.
How the hell am I supposed to rely on Asus products if they reliably crash like this for several firmware versions, released months in between? Would this be acceptable for the main electricity into my house? Especially these days, reliable internet is essential, and one would expect and established brand like Asus to understand that reliability is important above anything else in a router. Then how the f*** is is possible that numerous forum users are discovering the same errors for a long time, even years back this has been a frequent issue. Do they even do basic testing in an environment before pushing this useless s**t out through the release-channel?
Astounded by the lack of attention this receives.
EDIT: Two new members to the club:
Hello! New to this forum! So I have 2 of these routers set up and for the past 2 years we have been trying almost everything to fix this issue to no avail so now I turn to you guys. We have had these routers probs around 3-4 years now. So basically I have one router as the "master" and another...
www.snbforums.com
I have AX56U with latest merlin firmware 386.4. The 5Ghz connection was dropped and it was being set to Open System (WPA2 before). Checked the log and I do see few lines of "Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)" Not sure if this is relevant but it is...
www.snbforums.com
EDIT2: aaaand, it goes on
Hi guys, I recently upgraded my ac88u to the latest beta [386.4_beta2 > 386.4_beta3] and for some odd reason speeds are extremely slow? VM M500 UK. No issues at Virgin Media, BQM is healthy. The only thing I did was update to the latest beta and update spdMerlin and Diversion - now my speeds...
www.snbforums.com
ON AX55 after reserving ip address for particular mac address, have lost connection to router interface. HTTPS was never enabled.. Same thing happened with me one more time. Within this issue: VPN client (wireguard) got disabled and connected clients lost VPN connection but able to connect to...
www.snbforums.com
I have Apple iMac siting at very close proximity to the GT-AX1100 so wireless signal strength is absolutely no the issue. Every hour like a clock work, I get a Deauthentication from GT-AX11000 so iMac does disconnect/authenticate/Associate sequence as seen on the sniffer capture (screenshot...
rog.asus.com
I recently bought the ASUS RT-AX82U router and have a fantastic signal with the 5ghz but the 2.4ghz signal is constantly dropping throughout the day. I've contacted ASUS support and shared my Wireless log and they indicated it is due to wireless interference. They suggested changing channels...
community.virginmedia.com
I've had TP-Link smart switches and plugs for the last 5 years and never had an issue. I recently updated the firmware on my router (Asus GT-AX11000) and updated my iPhone's IOS to 15 and nothing but problems. Switches and plugs w/ Hardwa
community.tp-link.com
Have two Samsung A6 tablets that both now have issues connecting to WIFi since last dirty update. So reset router to factory defaults wiping out everything and manual reconfigured with settings that have work fine in v386.2 and earlier using WPA2-Personal AES Using either frequencies, will not...
www.snbforums.com
https://www.reddit.com/r/WeMo/comments/krmgzp
In swedish:
https://www.sweclockers.com/forum/trad/1622914-asus-rt-ac86u-tappar-internet-flera-ganger-per-dag
