AC86U system log "Resource temporarily unavailable"
krwy0330
My device is rt-ac86u with the latest asuswrt-merlin firmware 386.2_6.
I have installed entware and added a 256MB swap file.
When the equipment runs for more than three days, the system becomes unstable. It's unable to restart from web page or scheduled task. And ssh connection returns "kex_exchange_identification: Connection closed by remote host". Also, the system status in the web page shows nothing.
The system log often shows "crond[1913]: vfork: Resource temporarily unavailable",
and when I use ssh to connect, it will show "dropbear[13919]: vfork: Resource temporarily unavailable".
How should I tune the router without restarting it every two days.
ColinTaylor
Part of the Furniture
Try removing all Entware scripts/processes you have installed and see if the problem goes away. If it does then review the system requirements of your Entware scripts/processes.
krwy0330
Thank you, I resolve the problem by restart transmission-daemon every day.
