After upgrade to 386.7 warning about low level of free NVRAM
yse
Hello,
After upgading my ASUS RT-AC68U to the new 386.7 version of Merlin there is a flashing warning in top right corner of the GUI saying:
"Your router is running low on free NVRAM, which might affect its stability.
Review long parameter lists (like DHCP reservations), or consider doing a factory default reset and reconfiguring."
The NVRAM values:
Internal Storage
NVRAM usage 62808 / 65536 bytes
JFFS 3.63 / 62.75 MB
When SSH into the router and NVRAM SHOW it shows that quite a few parameters are empty e.g.
wl1.1_key4=
wan1_dns2_x=
apps_download_file=
zebra_enpasswd=ZkJCu+uJGig+hx7q/Yu97A==
wl0.2_radius_ipaddr=
wan1_hwaddr=
Can the "empty" parameters be removed to minimize the NVRAM?
Stefan
ColinTaylor
Part of the Furniture
Generally speaking, no. Some of them still have meaning even if they're "empty". Other's will just be recreated the next time the router is rebooted. The only sensible way to clear out obsolete nvram variables is to do a factory reset followed by a manual configuration.
yse
Ok, thanks for promt reply!
What does a factory reset mean after installing Merlin? Back to standard firmware or Merlin?
John Fitzgerald
Factory Reset via the ADMINISTRATION tab: PUT A CHECK IN THE BOX next to Restore button.
AFTER you save your settings: EDIT: Reloading the old settings may reintroduce your problems.
ColinTaylor
It doesn't change the firmware version. It just wipes out the user settings - so you'll be back at the initial router setup dialog.
P.S. You can save your current settings and JFFS in case something goes wrong and you need to revert. But for this exercise do not restore the settings file(s) as that would negate the whole point of doing the factory reset.
OzarkEdge
gattaca
