RT-AC68U / asuswrt-merlin 380.64 low nvram
syndicatedragon
I recently updated to 380.64. Now there is a blinking "!" in the corner of the router web screen and a popup says I am low on nvram.
On the sysinfo page it says
NVRAM usage 63929 / 65536 bytes
JFFS 2.01 / 62.75 MB
Do I need to free up more nvram? What is the best way to do this?
OK, sorry. I tried to search and I didn't find that thread. Thanks.
edit - it worked. after factory reset:
NVRAM usage 46244 / 65536 bytes
JFFS 1.68 / 62.75 MB
So, upgrading the firmware does not move the file until a default reset is done?
hello
i have some bug.
fault in client list. i have 270
as a result client_info_tmp in nvram Filled with garbage
and I think it's guilty of OpenVpn server
