AIMesh/Merlin ASUS RT-AC88u main RT-AC86u node
MrBill94592
Any advise on a newer/stable Merlin firmware with AIMesh using ASUS RT-AC88u as host router and RT-AC86u as wired node???
I’m currently using Merlin 3.0.0.4.386.2_4 on the RT-AC88u (Host).
*** and ***
ASUS official 3.0.0.4.386.43129 on the RT-AC86u (Node).
L&LD
Part of the Furniture
Welcome to the forums @MrBill94592.
Both of those firmwares are out of date. (By a lot).
I would also consider using the better router as the main router too (the RT-AC86U).
MrBill94592
I tried using newer firmware and it did not work
I found a recommendation on this site which stated the versions I used.
L&LD
But, did you try using the higher spec'd model as the main router? That would be the RT-AC86U.
Pergola Fabio
i run too ac88 as main, merlin 382.2.4
and stock firmware on 86u ...
never run merlin on nodes, i had them running , ethernect backhaul, struggled for months, nodes disconnected always after x days, upgraded to stock in node, problem gone!!
