Hi All thanks for the responses so far seems I have kicked of a major talking point lol so just to clarify I am on VM 500 connection currently with a AC68U x 2 running on Aimesh with hardwire backhaul connection infact my whole house is hardwired x 8 connections total did this during a electrical rewire.
As we took out a 02 contract with VM have been given a free speed boost from 500 to 1gbs.
I believe the saying if it ain’t broke don’t fix it my 2 x AC68U have run flawlessly with VM500 getting the full speed I believe the AC68U is perfectly capable off getting 900mbps down and as most of the important devices are already hardwired xbox etc.
I can pickup the AC88U for £60 so thought having 8 wired connections I could utilise the 8 ports and remove one tp-link switch and free up a plug socket and some electrical power
wifi 5 is more then enough for our needs.
so the question really was to ensure that I could use the AC88U as a main router and then make the 2x AC68U Aimesh nodes with hardwire backhaul.
ensuring that this setup would compatible etc but by the sounds of it I make as well stick to my 2 x AC68u as it works perfectly fine and if I get 900mbps that’s perfectly fine as 500mbps is currently perfectly fine may as well just say £60.
thx
H
