Is it me or did Asus just skip the gt2900. The ac86u has had a update one month ago. But the gt is a full year past. Or is it just me....
So let's make it a ac86u then![]()
Anyways I do like the 160mhz support ..
Well iam not a gamer type. I just like the rog interface. Besides i only got it for the 160mhz support. It operates Infront of the 86u. I opened them up both. And except the RGB the units are pretty much the same. So yeah money not we'll spend.
I now have it as a mesh node. And the 86u in the closet for any moment. The main router now is the ax86 and it seems to do a awesome job for now. Later on iam planning to get a new main router and add the current one as node.
Sounds like you put the supported router in the closet for a webUI you are not using and a 160MHz backhaul that will always be marginal by DFS-design... if that backhaul is not 99.9999% reliable, the best upgrade you can make for your network is to wire the backhaul.
OE
I have a wired backhaul. It's only for close clients to maximize data transport.
It is but i don't get the aimesh stuff. About mixing ac and ax clients. My ac unit is downstairs as main and the gt is node upstairs. But it's somehow not stable...
Most devices have a ac connection. I have a few devices that handle ax. And with my fiber connection at 1gb i do manage to get that wireless.
Upstairs i don't care that much. But i do care about seamless roaming and somehow when I set the unit to app mode. It's not flawless. When i use aimesh it is seamless.
What do you use it for? There was one single internal card supporting it and few Chinese phones/tablets.
BCM4366E supports 160MHz, but it was cut off RT-AC86U model for marketing reasons. Someone had to have a reason to buy GT-AC2900 different than RGB lights. It had VPN Fusion like other ROG models as additional plus. This model didn't go well and was often sold cheaper than RT-AC86U.
Welcome To SNBForums
