Asus GT-AX11000 problems
jlodvo
ive been having tons of problems from my ax11000, getting wifi drop outs also lan having problems its like the router is choking , and a notice a pattern like after 2 weeks of use i need to reset factory defaults on the router or i can surf the net, its like a memory leak on pc, but reboot or on/off doesnt fix it
and also look at the system log is this normal?
Feb 18 08:31:21 kernel: nf_conntrack: expectation table full
Feb 18 08:31:26 kernel: nf_conntrack: expectation table full
Feb 18 09:35:54 acsd: acs_candidate_score_intf(995): eth7: intf check failed for chanspec: 0xe832 (36/160)
Feb 18 09:35:54 acsd: acs_candidate_score_bgnoise(1312): eth7: bgnoise check failed for chanspec: 0xe832 (36/160)
Feb 18 09:35:54 acsd: acs_candidate_score_txop(1563): eth7: txop check failed for chanspec: 0xe832
Feb 18 09:35:54 acsd: acs_candidate_score_intf(995): eth7: intf check failed for chanspec: 0xe932 (40/160)
Feb 18 09:35:54 acsd: acs_candidate_score_bgnoise(1312): eth7: bgnoise check failed for chanspec: 0xe932 (40/160)
Feb 18 09:35:54 acsd: acs_candidate_score_txop(1563): eth7: txop check failed for chanspec: 0xe932
Feb 18 09:35:54 acsd: acs_candidate_score_intf(995): eth7: intf check failed for chanspec: 0xea32 (44/160)
Feb 18 09:35:54 acsd: acs_candidate_score_bgnoise(1312): eth7: bgnoise check failed for chanspec: 0xea32 (44/160)
Feb 18 09:35:54 acsd: acs_candidate_score_txop(1563): eth7: txop check failed for chanspec: 0xea32
Feb 18 09:35:54 acsd: acs_candidate_score_intf(995): eth7: intf check failed for chanspec: 0xeb32 (48/160)
Feb 18 09:35:54 acsd: acs_candidate_score_bgnoise(1312): eth7: bgnoise check failed for chanspec: 0xeb32 (48/160)
Feb 18 09:35:54 acsd: acs_candidate_score_txop(1563): eth7: txop check failed for chanspec: 0xeb32
