Ladies / Gents,
I am not a specialist in networking and my system at home works as it should do under normal circumstances!
It is setup as follows:
I know the cascade setup will be frowned upon, however this is the only way I can do it with my service provider (Kabel Deutschland / Vodafone).
Fritz!Box 6490 Supplied By Kabel Deutschland - My Telephone Numbers Pre Configured - No possibility to add SIP Accounts to this Router.
ASUS RT-AC68U (Merlin Firmware 380.58) - Primary Router
Fritz!Box 7490 Purchased - SIP Telephony Only - Multiple SIP Accounts setup within this Router.
I need help with the following problems that occur when I connect to an Open VPN client within the VPN section of the router:
1) All SIP Accounts lose connection and do not re-register with my service providers.
2) I cannot connect to PC CYBERSYSTEM1 Using RealVNC (When I am not connected to the Open VPN Client remote management of PC is fine.
Can anyone see any reason to as and why this would be the case and what would be the solution?
My Open VPN Client is configured as follows:
Is there anything that I need to add to custom configuration to allows the said services to work when connected to the Open VPN Client?
Thanks in advance!
Vee
Thanks in advance!
Vee
