I'm thinking of picking up a AC router and wondering if the Asus ones will fit my needs?
I need one that supports ddwrt or will the merlin firmware allow similar functionality?
What I need:
Ability to run custom scripts
Good wifi range on both 2.4/5GHz
Gigabit LAN
Guest mode (control SSID, encryption, lease time)
Ability to set up as a wireless AP with guest mode as well (previous dlink would not work with a guest ssid coz I was not using the WAN port)
What I need:
Gigabit LAN
