Release Asuswrt-Merlin 3004.388.10 is now available
Just noticed, that everytime I use the App (testing) I see this in the log after a few seconds of starting it. Both on the nodes and the router.
Oct 31 15:07:43 Router HTTPD: [LOGIN][https][APP] success (192.168.1.173)
Oct 31 15:07:54 Router rc_service: cfg_server 1498:notify_rc stop_fw_check
Oct 31 15:07:54 Router custom_script: Running /jffs/scripts/service-event (args: stop fw_check)
Oct 31 15:07:55 Router rc_service: cfg_server 1498:notify_rc start_fw_check
Oct 31 15:07:55 Router custom_script: Running /jffs/scripts/service-event (args: start fw_check)
Not so with logging in to the GUI/Web. Doesn't appear to cause any issues but I did get this, the first time I use the App but have not been able to reproduce it so maybe coincidence 🤷‍♂️
Oct 31 15:03:32 Router kernel: Init chrdev /dev/idp with major 190
Oct 31 15:03:32 Router kernel: tdts: tcp_conn_max = 8000
Oct 31 15:03:32 Router kernel: tdts: tcp_conn_timeout = 300 sec
Oct 31 15:03:34 Router kernel: SHN Release Version: 2.0.2 36f59aa
Oct 31 15:03:34 Router kernel: UDB Core Version: 0.2.20
Oct 31 15:03:34 Router kernel: Init chrdev /dev/idpfw with major 191
Oct 31 15:03:34 Router kernel: IDPfw: flush fc
Oct 31 15:03:34 Router kernel: IDPfw: IDPfw is ready
Oct 31 15:03:34 Router kernel: sizeof forward pkt param = 280
Oct 31 15:03:51 Router kernel: IDPfw: Exit IDPfw
Oct 31 15:03:51 Router kernel: mod epilog takes 0 jiffies
Oct 31 15:03:51 Router kernel: Exit chrdev /dev/idpfw with major 191
Oct 31 15:03:51 Router kernel: Exit chrdev /dev/idp with major 190
Please give these test builds a try. They include the fix provided by Asus for the httpd server crashing when logging in using the APP API.
This is the only change at this time.
Dirty upgrade from 3004.388.10 to 3004.388.10_1-g74977d9bf4. Now the AsusRouter iOS App is working as expected. Thank you so much @RMerlin for the Test Build, which fixes this issue.
Updated and all is running smooth. Thank you @RMerlin for everything!
It just means that the application automatically triggers a check for new firmware whenever you connect with it. Nothing unusual there, it`s probably simply how it works.
Dirty upgrade from 3004.388.10 to 3004.388.10_2 on main router, ~90 minutes in and smooth as silk. Great stuff! (AiMesh node still on stock.)
Nice to know. Because I run Scribe, it generates the entry in the systen log ;) I'll just ignore it
From my service-event in /jffs/scripts...
/jffs/scripts/scribe service_event "$@" & # added by scribe
Asus Router app works fine with new build, thanks RMerlin! 😁😁
Update completed from version 3004.388.10 to the new version 3004.388.10_2.
Rock solid so far.
Thank you RMerlin for your work... ;)
Everything updated to 10_2.
Everything is fine except for the inability to update AiMesh nodes remotely.
Thanks @RMerlin
Could you please expand on this, do you mean through the WebGui?
I don’t have an issue doing this if I VPN (Tailscale or Wireguard) to my remote router and upload FW to the nodes via the Router’s WebGui (where you use a Node Login screen), for nodes that do not support Merlin or (my preference) via the very capable MerlinAU Addon which does that “locally” if you have it installed on the Node (for nodes supporting Merlin and thus amtm).
Parental Controls didn't pick up the time change and locked the network for my child an hour earlier. A reboot fixed it.
via WebGui in 2 instalations diferents, one with Wireguard and the other whitout Wireguard. In local net, without problems.
Hmm odd. Maybe start a new separate thread detailing with screenshots or logs where appropriate, your steps taken and specifically what happens when you try to update FW remotely, error messages or observations. Include (blanking private information) screenshots or logs showing VPN is connected.
As above if the VPN tunnel is working correctly there should be no impediment to you accessing the WebGUI on the same router IP address as you do locally and updating the FW via the GUI.
Dirty upgraded my RT-AX86U from 3004_388.10 to 3004_388.10_2.
Update went fine and router rebooted well.
Thank you very much for your work
Dirty upgrade from 3004.388.10 to 3004.388.10_2 on my RT-AX86U.
Works good.
So now I can use the Asus router app?
Works good.
That's what fix was for. Try it...
Probably a stupid question, but can anybody explain what "Dirty upgrade" is?
I suppose is to upgrade without doing a factory reset, but I'm not sure.
Correct. It's a misnomer really as it's a "normal" update. I believe it comes about as attempted humour to indicate the opposite of a "clean install" (that Microsoft Windows users are familiar with).
@RMerlin there is a compatibility issue with Guest Networking and nodes that are on 3004 instead of 3006. The GT-AX11000 Pro had 3004 firmware but now is moved to the 3006 which cant seem to handle basic guest networking that the old 3004 branch was capable of handling. With a 3004 and a 3004 node I am able to have mesh network guest network on both my bands -- This doesn't work with Guest Network Pro. Is there a way to give users the choice and build both branches - Or are any fixes coming out for that - I know you don't handle that code specifically but even the new betas don't seem to have new code for wifi 6 routers. It looks like new GPL is just for wifi 7 routers.
