Beta Asuswrt-Merlin 386.6 beta is now available for select models
RMerlin
Asuswrt-Merlin dev
Asuswrt-Merlin 386.6 beta is now available, only for the GT-AX6000 and ZenWiFi Pro XT12.
April 13th: Beta 2 is now available.
d6866e6dc6 build: include *.pkgtb when generating sha256sums in build-all script
55d4a59cba webui: remove duplicate setting on Samba config page; remove legacy length check
2cb3accb13 rc: shared: webui: fix JFFS custom scripts/config support on UBI models; hide jffs fomating on these as it's currently not working
329cbad359 webui: remove duplicate setting on DDNS page (got added by upstream GPL merge)
2df45c7992 Bumped revision to beta 2
The focus of this release is the addition of these two new models to the list of supported devices, in addition to a few other improvements.
Summary of changes:
  • Merged with GPL 386_47885
  • Added support for the ZenWiFi Pro XT12
  • Added support for the GT-AX6000 (with the non-ROG webui and without VPNFusion, like other supported ROG models)
  • Added new IPv6 options to OpenVPN servers, allowing to disable/enable IPv6 support, and also to enable NAT (allowing remote clients to also redirect their IPv6 Internet traffic through their router's OpenVPN server
  • Updated components: wget (1.21.3), dropbear (2022.82)
  • Allow requesting bigger IPv6 subnets from your ISP
  • Fixed Traditional QoS download traffic limited by upstream bandwidth
Please consult the Changelog for the complete list of changes.
These two new models are based on a new SDK (HND 5.04), which includes a new Kernel version (4.19.183), so pretty much everything will need to be thoroughly tested. Note that as usual, anything wifi-related is closed source and therefore outside of my control.
Please keep discussions in this thread on the topic of this release and these two new models.
Downloads are here.
Changelog is here.
RMerlin
Asuswrt-Merlin dev
Known issues:
  • Not really a firmware issue, but the SHA256 hashes didn't get published to the servers by the build process. I will manually publish them later.
  • Duplicate setting on the SMB disk sharing and the DDNS setting (Fixed for beta 2)
  • jffs2_scripts nvram setting is missing after a factory default reset (Fixed for beta 2)
ResidualEffect
This is awesome, thank you for adding support for the GT-AX6000!
I had some time to install 386.6 beta 1 this evening over the stock asus firmware and things are working pretty well so far (about 2 hours in)!
I ran a factory reset after installing and ran in to the known issue with the jffs2_scripts nvram setting being missing, but I was able to add it manually via SSH to work around that for now and got a custom script working for now, but the admin interface is still not showing the JFFS scripts option as enabled.
I also had some difficulties related to changing the router's IP / DHCP IP Pool settings / IPv6 settings from their defaults. After changing any one of these settings, my desktop connected via the 2.5 gbit LAN port was unable to send/receive network traffic with the router or receive a new DHCP lease. Disconnecting and reconnecting the network cable or disabling & re-enabling network adapter on the desktop did not help. I was still able to connect via WiFi when this was happening and access the router configuration pages no problem. After waiting a while to see if things would recover, I rebooted the router and that fixed things immediately for the 2.5gbit port desktop, and things were back to working normally. I changed all 3 of these settings, and this same scenario played out for all 3 of these times. I'm not sure if I was doing something wrong on the desktop side, but I haven't experienced an issue like this with merlin firmware on my RT-AX88U.
Other than that everything seems to be running smoothly so far! I'll keep poking at it.
Connecting at 2.5gbps to my ISP with a 5 port 2.5 gbps switch for my desktop and NAS. Everything wired is running at 2.5gbps end to end finally with the GT-AX6000, plus 28 wifi clients and openvpn client and server all up and running exactly as expected so far.
Thanks again for your work on this new version!
John_
Loaded beta 1 on the GT-AX6000.
Looking good so far.
Issue from on the alpha on the Firewall - Network Services Filter page is gone.
Connection speed looks normal.
KingBravery
Now XT12 users can change their main router GT-AX11000 to this XT12.. What a beast combination.
mikezilla2
Fixed Traditional QoS download traffic limited by upstream bandwidth ?
if thats What i tihnk it is i thought that Would Never Get fixed ....
jsbeddow
I see this beta is only for select models... Are we dropping down to only supporting these two models?
No, other models will still be supported in the next release (386.7), so this was an exception to the norm.
See the official word from RMerlin here:
https://www.snbforums.com/threads/asuswrt-merlin-386-5-is-now-available.77691/post-756454
and here:
Jumpstarter
and here:
Thank you. I thought RMerlin was ready to make the work load easier. Didn't suspect a release just to support two new models though. Definitely off the RMerlin norm for sure.
Jumpstarter
Summary of changes:
Downloads are here.
Changelog is here.
So does the GT-AX6000 also work for the RT-AX89X? I managed to come upon three of these that I want to test RMerlin on.
L&LD
Part of the Furniture
They're not identical.
One is the RT-AX89X and the supported one is the GT-AX6000. Model numbers are important.
Raphie
So which ASUS Merlin supported router is currently then the “money no object, top of the bill, the dog’s bollocks“ is it the XT12? I want to replace my AC5300 with the best main router to match my AX86u upstairs (need 2.5gbit wired backhaul) and now have several AX wireless clients. My provider will move to 2.5gb Docsis modems soon as well.
is there an advantage replacing the AX86u as well and buy a XT duopack? Or is it just cosmetics? The AX86u is just used as mesh access point with wired backhaul. (Currenlty 1gbit)
qqq
gt-ax6000 386.6_beta1 Automatic restart bug feedback
Apr 10 15:15:35 dnsmasq-dhcp[10243]: DHCPREQUEST(br0) 192.168.50.89 52:54:******1c:77
Apr 10 15:15:35 dnsmasq-dhcp[10243]: DHCPACK(br0) 192.168.50.89 52:54:00:f6:1c:77 WIN-2012-ttx
Apr 10 15:15:52 hostapd: eth6: STA 54:ef******:49:cd WPA: group key handshake completed (RSN)
Apr 10 15:15:52 hostapd: eth6: STA 78:1******10:b1 WPA: group key handshake completed (RSN)
Apr 10 15:15:52 hostapd: eth6: STA 58:b6******:3a:e9 WPA: group key handshake completed (RSN)
Apr 10 15:15:52 hostapd: eth6: STA 5c:e******4:04 WPA: group key handshake completed (RSN)
Apr 10 15:15:52 hostapd: eth6: STA d4:******:3b:3b WPA: group key handshake completed (RSN)
Apr 10 15:15:52 hostapd: eth6: STA 8c******:4d:08 WPA: group key handshake completed (RSN)
Apr 10 15:15:52 hostapd: eth6: STA 54:48:******:f0:ad WPA: group key handshake completed (RSN)
Apr 10 15:15:52 hostapd: eth6: STA 7c:c******:e0:40 WPA: group key handshake completed (RSN)
Apr 10 15:15:52 hostapd: eth7: STA 60:7******4:47:b9 WPA: group key handshake completed (RSN)
Apr 10 15:15:52 hostapd: eth7: STA c2:5e******b:bc:2d WPA: group key handshake completed (RSN)
Apr 10 15:15:52 hostapd: eth6: STA 4c:24:******:fe:00 WPA: group key handshake completed (RSN)
Apr 10 15:15:53 wlceventd: wlceventd_proc_event(469): eth6: Deauth_ind 54******:C8:49:CD, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Apr 10 15:15:53 wlceventd: wlceventd_proc_event(486): eth6: Disassoc 54:EF:4******9:CD, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Apr 10 15:15:53 hostapd: eth6: STA 54:ef******49:cd IEEE 802.11: disassociated
Apr 10 15:15:53 hostapd: eth6: STA 54:ef:44******49:cd IEEE 802.11: disassociated
Apr 10 15:15:53 wlceventd: wlceventd_proc_event(505): eth6: Auth 54:EF******8:49:CD, status: Successful (0)
Apr 10 15:15:53 wlceventd: wlceventd_proc_event(534): eth6: Assoc 54:EF:******8:49:CD, status: Successful (0)
Apr 10 15:15:53 hostapd: eth6: STA 54:e******:49:cd IEEE 802.11: associated
Apr 10 15:15:53 hostapd: eth6: STA 54:ef******:49:cd RADIUS: starting accounting session B0DF92EB9846F227
Apr 10 15:15:53 hostapd: eth6: STA 54:e******49:cd WPA: pairwise key handshake completed (RSN)
Apr 10 15:32:10 wlceventd: wlceventd_proc_event(505): eth7: Auth 7A:2C:******D6:62, status: Successful (0)
Apr 10 15:32:10 wlceventd: wlceventd_proc_event(534): eth7: Assoc 7A:2******D6:62, status: Successful (0)
Apr 10 15:32:10 hostapd: eth7: STA 7a:2******d6:62 IEEE 802.11: associated
Apr 10 15:32:10 hostapd: eth7: STA 7a:2******d6:62 RADIUS: starting accounting session 829CEC645A2FE26A
Apr 10 15:32:10 hostapd: eth7: STA 7a:2******d6:62 WPA: pairwise key handshake completed (RSN)
Apr 10 15:32:11 dnsmasq-dhcp[10243]: DHCPREQUEST(br0) 192.168.50.139 7a:2******d6:62
Apr 10 15:32:11 dnsmasq-dhcp[10243]: DHCPACK(br0) 192.168.50.139 7a:2c:fc:****** SM-R8950
Apr 10 15:39:16 wlceventd: wlceventd_proc_event(486): eth7: Disassoc 7A:2******6:62, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Apr 10 15:39:16 wlceventd: wlceventd_proc_event(469): eth7: Deauth_ind 7A:2C******D6:62, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Apr 10 15:39:16 hostapd: eth7: STA 7a:******d6:62 IEEE 802.11: disassociated
Apr 10 15:39:16 hostapd: eth7: STA 7a:2c:******d6:62 IEEE 802.11: disassociated
Apr 10 15:52:28 wlceventd: wlceventd_proc_event(505): eth7: Auth 40:******2D:66, status: Successful (0)
Apr 10 15:52:28 wlceventd: wlceventd_proc_event(534): eth7: Assoc 40:4E******:2D:66, status: Successful (0)
Apr 10 15:52:28 hostapd: eth7: STA 40:******:66 IEEE 802.11: associated
Apr 10 15:52:28 hostapd: eth7: STA 40:4e:******d:66 RADIUS: starting accounting session E23338B093F1F685
Apr 10 15:52:28 hostapd: eth7: STA 40:4e:******:2d:66 WPA: pairwise key handshake completed (RSN)
Apr 10 15:52:32 dnsmasq-dhcp[10243]: DHCPDISCOVER(br0) 40:4e:******d:66
Apr 10 15:52:32 dnsmasq-dhcp[10243]: DHCPOFFER(br0) 192.168.50.134 40:4e******d:2d:66
Apr 10 15:52:33 dnsmasq-dhcp[10243]: DHCPDISCOVER(br0) 40:4e******:2d:66
Apr 10 15:52:33 dnsmasq-dhcp[10243]: DHCPOFFER(br0) 192.168.50.134 40:4e:******d:66
Apr 10 15:52:33 dnsmasq-dhcp[10243]: DHCPREQUEST(br0) 192.168.50.134 40:4e:3******2d:66
Apr 10 15:52:33 dnsmasq-dhcp[10243]: DHCPACK(br0) 192.168.50.134 ******2d:66 android-419b7b8d4885e8ea
Apr 10 16:00:01 wlceventd: wlceventd_proc_event(486): eth7: Disassoc 40:4E:3******D:66, status: 0, reason: Unspecified reason (1)
Apr 10 16:00:01 wlceventd: wlceventd_proc_event(469): eth7: Deauth_ind 40:4E:******2D:66, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Apr 10 16:00:01 hostapd: eth7: STA 40:4e******:66 IEEE 802.11: disassociated
Apr 10 16:00:01 hostapd: eth7: STA 40:4e******2d:66 IEEE 802.11: disassociated
Apr 10 16:15:52 hostapd: eth6: STA 54:ef******8:49:cd WPA: group key handshake completed (RSN)
Apr 10 16:15:52 hostapd: eth6: STA 58:b6******:3a:e9 WPA: group key handshake completed (RSN)
Apr 10 16:15:52 hostapd: eth6: STA 78:11******8:10:b1 WPA: group key handshake completed (RSN)
Apr 10 16:15:52 hostapd: eth6: STA 5c:e5******3c:44:04 WPA: group key handshake completed (RSN)
Apr 10 16:15:52 hostapd: eth6: STA d4:35******5e:3b:3b WPA: group key handshake completed (RSN)
Apr 10 16:15:52 hostapd: eth6: STA 8c:53:******4d:08 WPA: group key handshake completed (RSN)
Apr 10 16:15:52 hostapd: eth6: STA 7c:c2:9******:e0:40 WPA: group key handshake completed (RSN)
Apr 10 16:15:52 hostapd: eth6: STA 54:48******eb:f0:ad WPA: group key handshake completed (RSN)
Apr 10 16:15:52 hostapd: eth7: STA 60:7e:a******4:47:b9 WPA: group key handshake completed (RSN)
Apr 10 16:15:52 hostapd: eth7: STA c2:5******db:bc:2d WPA: group key handshake completed (RSN)
Apr 10 16:15:52 hostapd: eth6: STA 4c:2******6e:fe:00 WPA: group key handshake completed (RSN)
Apr 10 16:15:53 wlceventd: wlceventd_proc_event(469): eth6: Deauth_ind 54:E******49:CD, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Apr 10 16:15:53 wlceventd: wlceventd_proc_event(486): eth6: Disassoc 54:E******:49:CD, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Apr 10 16:15:53 hostapd: eth6: STA 54:e******c8:49:cd IEEE 802.11: disassociated
Apr 10 16:15:53 hostapd: eth6: STA 54:e******:49:cd IEEE 802.11: disassociated
Apr 10 16:15:53 wlceventd: wlceventd_proc_event(505): eth6: Auth 54:EF:44:C8:49:CD, status: Successful (0)
Apr 10 16:15:53 wlceventd: wlceventd_proc_event(534): eth6: Assoc 54:EF:44:C8:49:CD, status: Successful (0)
Apr 10 16:15:53 hostapd: eth6: STA 54:e******49:cd IEEE 802.11: associated
Apr 10 16:15:54 hostapd: eth6: STA 54:e******8:49:cd RADIUS: starting accounting session 76343BB717DB8425
Apr 10 16:15:54 hostapd: eth6: STA 54:******8:49:cd WPA: pairwise key handshake completed (RSN)
May  5 13:05:17 syslogd started: BusyBox v1.25.1
May  5 13:05:17 kernel: klogd started: BusyBox v1.25.1 (2022-04-08 19:28:08 EDT)
May  5 13:05:17 kernel: Booting Linux on physical CPU 0x0000000000 [0x420f1000]
May  5 13:05:17 kernel: Linux version 4.19.183 ([email protected]) (gcc version 9.2.0 (Buildroot 2019.11.1)) #1 SMP PREEMPT Fri Apr 8 19:28:22 EDT 2022
May  5 13:05:17 kernel: Machine model: GTAX6000_50991
May  5 13:05:17 kernel: earlycon: pl11 at MMIO 0x00000000ff812000 (options '115200n8')
May  5 13:05:17 kernel: bootconsole [pl11] enabled
May  5 13:05:17 kernel: Reserved memory: created CMA memory pool at 0x0000000035000000, size 176 MiB
May  5 13:05:17 kernel: OF: reserved mem: initialized node dt_reserved_cma, compatible id shared-dma-pool
May  5 13:05:17 kernel: psci: probing for conduit method from DT.
May  5 13:05:17 kernel: psci: PSCIv1.1 detected in firmware.
May  5 13:05:17 kernel: psci: Using standard PSCI v0.2 function IDs
May  5 13:05:17 kernel: psci: MIGRATE_INFO_TYPE not supported.
May  5 13:05:17 kernel: psci: SMC Calling Convention v1.1
May  5 13:05:17 kernel: random: get_random_bytes called from start_kernel+0x9c/0x454 with crng_init=0
May  5 13:05:17 kernel: percpu: Embedded 32 pages/cpu s92888 r8192 d29992 u131072
May  5 13:05:17 kernel: Detected VIPT I-cache on CPU0
May  5 13:05:17 kernel: CPU features: enabling workaround for ARM erratum 843419
May  5 13:05:17 kernel: CPU features: enabling workaround for ARM erratum 845719
May  5 13:05:17 kernel: Speculative Store Bypass Disable mitigation not required
May  5 13:05:17 kernel: CPU features: detected: Kernel page table isolation (KPTI)
May  5 13:05:17 kernel: Built 1 zonelists, mobility grouping on.  Total pages: 258048
May  5 13:05:17 kernel: Kernel command line: coherent_pool=4M cpuidle_sysfs_switch pci=pcie_bus_safe console=ttyAMA0,115200 earlycon rootwait mtdparts=brcmnand.0:2097152(loader),[email protected](image),[email protected](crashlog) root=/dev/ubiblock0_4 ubi.mtd=image ubi.block=0,4 rootfstype=squashfs cma=0M
qqq
Continue above:
May  5 13:05:17 kernel: log_buf_len individual max cpu contribution: 16384 bytes
May  5 13:05:17 kernel: log_buf_len total cpu_extra contributions: 49152 bytes
May  5 13:05:17 kernel: log_buf_len min size: 65536 bytes
May  5 13:05:17 kernel: log_buf_len: 131072 bytes
May  5 13:05:17 kernel: early log buf free: 63256(96%)
May  5 13:05:17 kernel: Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
May  5 13:05:17 kernel: Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
May  5 13:05:17 kernel: Memory: 838176K/1048576K available (6718K kernel code, 484K rwdata, 1664K rodata, 448K init, 384K bss, 30176K reserved, 180224K cma-reserved)
May  5 13:05:17 kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
May  5 13:05:17 kernel: rcu: Preemptible hierarchical RCU implementation.
May  5 13:05:17 kernel:     Tasks RCU enabled.
May  5 13:05:17 kernel: NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
May  5 13:05:17 kernel: GIC: Using split EOI/Deactivate mode
May  5 13:05:17 kernel: arch_timer: cp15 timer(s) running at 50.00MHz (phys).
May  5 13:05:17 kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xb8812736b, max_idle_ns: 440795202655 ns
May  5 13:05:17 kernel: sched_clock: 56 bits at 50MHz, resolution 20ns, wraps every 4398046511100ns
May  5 13:05:17 kernel: BRCM Legacy Drivers' Helper, all legacy drivers' IO memories/interrupts should be remapped here
May  5 13:05:17 kernel:      Remapping interrupts...
May  5 13:05:17 kernel:              hwirq      virq
May  5 13:05:17 kernel:                51         5
May  5 13:05:17 kernel:                60         6
May  5 13:05:17 kernel:                61         7
May  5 13:05:17 kernel:               107         8
May  5 13:05:17 kernel:               108         9
May  5 13:05:17 kernel:               109        10
May  5 13:05:17 kernel:               110        11
May  5 13:05:17 kernel:               111        12
May  5 13:05:17 kernel:               112        13
May  5 13:05:17 kernel:               113        14
May  5 13:05:17 kernel:               114        15
May  5 13:05:17 kernel:               115        16
May  5 13:05:17 kernel:               116        17
May  5 13:05:17 kernel:               117        18
May  5 13:05:17 kernel:               118        19
May  5 13:05:17 kernel:               119        20
May  5 13:05:17 kernel:               120        21
May  5 13:05:17 kernel:               121        22
May  5 13:05:17 kernel:               122        23
May  5 13:05:17 kernel:               123        24
May  5 13:05:17 kernel:               124        25
May  5 13:05:17 kernel:               125        26
May  5 13:05:17 kernel:               126        27
May  5 13:05:17 kernel:               127        28
May  5 13:05:17 kernel:               128        29
May  5 13:05:17 kernel:               129        30
May  5 13:05:17 kernel:               130        31
May  5 13:05:17 kernel:               131        32
May  5 13:05:17 kernel:               132        33
May  5 13:05:17 kernel:               133        34
May  5 13:05:17 kernel:               134        35
May  5 13:05:17 kernel:               135        36
May  5 13:05:17 kernel:               136        37
May  5 13:05:17 kernel:               137        38
May  5 13:05:17 kernel:               138        39
May  5 13:05:17 kernel:               139        40
May  5 13:05:17 kernel:                73        41
May  5 13:05:17 kernel:                74        42
May  5 13:05:17 kernel:                99        43
May  5 13:05:17 kernel:                69        44
May  5 13:05:17 kernel:      Remapping IO memories...
May  5 13:05:17 kernel:              phys              virt          size
May  5 13:05:17 kernel:        00000000ff800000  ffffff8008024000  00003500
May  5 13:05:17 kernel:        00000000ff85a000  ffffff800800d000  00001000
May  5 13:05:17 kernel:        00000000ff810000  ffffff800802a000  00001300
May  5 13:05:17 kernel:        00000000ff812000  ffffff8008030000  00003000
May  5 13:05:17 kernel:        00000000ffe00000  ffffff8008b00000  00100000
May  5 13:05:17 kernel:        00000000ff860000  ffffff8008034000  00002000
May  5 13:05:17 kernel:        0000000083010a00  ffffff8008015a00  00000100
May  5 13:05:17 kernel:        0000000080040000  ffffff8008040000  00040000
May  5 13:05:17 kernel:        0000000080144000  ffffff8008021000  00001000
May  5 13:05:17 kernel:        0000000080148000  ffffff8008090000  00008b00
May  5 13:05:17 kernel:        0000000080158000  ffffff800802d000  00000400
May  5 13:05:17 kernel:        0000000080160000  ffffff80080a0000  0000e000
May  5 13:05:17 kernel:        0000000080140000  ffffff8008038000  00004000
May  5 13:05:17 kernel:        0000000082890000  ffffff80080b0000  0000ac00
May  5 13:05:17 kernel:        0000000082000000  ffffff8009000000  00caf004
May  5 13:05:17 kernel:        0000000083400000  ffffff800a000000  00400000
May  5 13:05:17 kernel:        0000000080008000  ffffff8008084000  00004000
May  5 13:05:17 kernel:        00000000800c0000  ffffff80080c0000  0000ffff
May  5 13:05:17 kernel:        0000000081060000  ffffff800808c000  00003000
May  5 13:05:17 kernel:        0000000083800000  ffffff800a800000  00450000
May  5 13:05:17 kernel:        0000000080130000  ffffff80080d4000  00004000
May  5 13:05:17 kernel:        00000000837f0000  ffffff80080e0000  00008000
May  5 13:05:17 kernel:        00000000828b2000  ffffff800803d000  00001000
May  5 13:05:17 kernel:        0000000081100000  ffffff8008d00000  00091000
May  5 13:05:17 kernel:        0000000080020000  ffffff80080ec000  00004000
May  5 13:05:17 kernel:        0000000083000000  ffffff8008081000  00001000
May  5 13:05:17 kernel:        0000000083030000  ffffff80080f4000  00004000
May  5 13:05:17 kernel:        0000000083038000  ffffff8008a94000  00004000
May  5 13:05:17 kernel:        0000000083040000  ffffff8008a9c000  00004000
May  5 13:05:17 kernel:        0000000083048000  ffffff8008aa4000  00004000
May  5 13:05:17 kernel:        0000000083020000  ffffff8008aac000  00004000
May  5 13:05:17 kernel:        0000000083010000  ffffff8008ab4000  00004000
May  5 13:05:17 kernel:        0000000083018000  ffffff8008abc000  00004000
May  5 13:05:17 kernel:        0000000083058000  ffffff8008ac4000  00004000
May  5 13:05:17 kernel:        0000000083060000  ffffff8008acc000  00004000
May  5 13:05:17 kernel:        0000000083070000  ffffff8008ad4000  00004000
May  5 13:05:17 kernel:        0000000083078000  ffffff8008adc000  00004000
May  5 13:05:17 kernel:        0000000083080000  ffffff8008ae4000  00004000
May  5 13:05:17 kernel:        0000000083050000  ffffff8008aec000  00004000
May  5 13:05:17 kernel:        0000000083028000  ffffff8008af4000  00004000
May  5 13:05:17 kernel:        0000000083088000  ffffff8008c04000  00004000
May  5 13:05:17 kernel:        00000000810a0000  ffffff8008089000  00001000
May  5 13:05:17 kernel:        0000000083090000  ffffff800809a000  00000400
May  5 13:05:17 kernel:        0000000083094000  ffffff800809c000  00000400
