Beta Asuswrt-Merlin 386.12 Beta is now available for AC models
RMerlin
Asuswrt-Merlin dev
Staff member
Asuswrt-Merlin 386.12 beta 1 is now available, for supported Wifi 5 models.
Changes since 386.11:
  - UPDATED: Merged with GPL 386_51997.
  - UPDATED: curl to 8.1.2.
  - UPDATED: OpenVPN to 2.6.6.
  - UPDATED: openssl to 1.1.1u.
  - UPDATED: tor to 0.4.7.13.
  - CHANGED: FTP server will now only support strong ciphers
             in TLS mode.
  - FIXED: QOS Classification showing no Upload data on some
           WAN configurations.
  - FIXED: Radio temperature graphs weren't updating
  - FIXED: nvram usage reported on Sysinfo page was inaccurate
           as it included JFFS stored values.
Downloads are here.
Changelog is here.
Reserved post.
Edit: Custom device icons still not working
Can you elaborate? This is way too vague...
I'm not able to add my custom device icons, it used to work pre 386.12 builds
Updated to 386.12 beta 1 from 386.11 without issue.
As had been previously stated in the Alpha builds Custom Device Icons not displaying in this build as well (All my Network devices and computers have custom icons).
Reverted back to 386.11 for now.
Smooth dirty upgrade from alpha.
Not experiencing network issues of any kind!
I concur that custom device icons are not working.
Here are two examples of icons not currently working:
24 hours uptime with no issues so far. Network has been stable
Totally smooth dirty upgrade for me!
Thanks, Eric, for a really great upgrade!
All good at a remote site with RT-AC68U router and RT-AC68U AiMesh node (hardwired).
In this beta can anyone confirm if you do a fresh wipe you don't lose access to the GUI? I know in the Alpha it was broken.
That was resolved in the second iteration of alpha 1.
I did a dirty upgrade and again have access to the GUI.
I was somewhat hesitant because I am using this now principally as a VPN TAP client and there had been reports of reboots. I haven't had that with the alpha or with this beta.
But: I have this set as a VPN TAP client, redirecting all traffic (but not via VPN Director, which doesn't accept all to all), with strict DNS to a VPN TAP server with an upload capacity of 10mbps. My speedtest speeds are over 60, and my IP is reported in a location other than the server, so traffic is going outside the tunnel.
No issues on my setup after 3 days. 3-AC1900Ps and 3-AC68Us
Has the memory leak in networkmap / asd been fixed in this version?
