Beta ASUSWRT Official beta 386-RC1 for RT-AX89X
ASUSWRT_2020
Hi There,
Here is the official beta of RT-AX89X, we plan to update RT-AX89X to 386 branch soon, and now release candidate is under public sharing.
Download link:
https://asus-my.sharepoint.com/:u:/...lEi4Zmlb6NFOkBbQzESYMelZ5UGPkNG4qyNg?e=eab0T1
backup:
https://drive.google.com/file/d/15x2KAkHzzca_c2P0jgnegjVNSUt_x6MB/view?usp=sharing
Be noted(Please read this before you use):
1. Although these are release candidates, but still under testing, there might be some bugs will cause system unstable, if you are facing issues, please leave your comments in this thread.
2. Please update to https://www.asus.com/Networking/RT-AX89X/HelpDesk_BIOS/ 3004.384.82800 first, then to this beta.
3. By using 9.0.0.x beta, it will not get live update from official path, you need to flash to official 3.0.0.x release to get latest updates.
4. For updating firmware manually please refer to: https://www.asus.com/support/FAQ/1035199/
I have an ax89x and several ax88u routers, will this be also receiving all the AiMESH 2.0 features as in the rc2 for the other devices?
I can't see why not?
That's not 386 beta firmware.
OE
OK, fill me in on the benefit of beta firmware please.
I've never used beta firmware, isn't it much better to use the final true and tested firmware?
This thread is for anyone who wants to help beta test the subject firmware.
If you don't know what that means, Google it and read up. For example:
OE
I know what beta firmware is but it didn't click...sorry, I wasn't too attentive, embarrassing for sure :-)
Did I read the notes correctly? GT-AX11000 now supported?
Have a pretty stable AX11000 and I'm game to put a little time in Beta -
Trav..
Hi There,
Download link:
backup:
3. By using 9.0.0.x beta, it will not get live update from official path, you need to flash to official 3.0.0.x release to get the latest updates.
Well on my RT-AX89X this firmware introduced very high latency initially (circa 400ms to the router) and some packet loss using WIFI (haven't checked wired).
I also noticed some bugs when toggling OFDMA/802.11ax MU-MIMO in professional settings. Had to toggle back and forth between modes as it was showing disabled (even though it was enabled before the upgrade).
I reset back to factory defaults and reconfigured and it works fine.
However, it's disappointing that there's still no DNS over TLS support
WPA3 is there but can't be used as my older network cards don't support it.
