Beta ASUSWRT 386 RC3-2 public beta
ASUSWRT_2020
Hi All,
In the past few weeks, we focused improved the security and postponed the 386 RC3-2 a little. Here are the major new features.
(1) Instant Guard can now invite your family members or friends.
The previous version is for administrator only. In this new version, we modified the server, firmware, and app to let you share the router's VPN connection easily. To try this feature, please upgrade both the firmware to 386 rc3-2 and the Instant Guard app.
Android ipk link: https://drive.google.com/drive/folders/1lPARbpUu5YaZrW4VdVuJskb9DK8_VcXI?usp=sharing
iOS: Please pm me you apple ID email and I will add you to the TestFlight beta tester list.
(2) Support reward time in parental control. You can increase extra time for children in the network blocking period.
We removed the DNS filter in 386 RC3-2 because of the concern about the trademark. We are developing the similar feature with different name and UI instead of DNS filter.
The 386 RC3-2 firmware link
https://drive.google.com/drive/folders/1wvFKrOprbgDcrTk6yh84OOm8uZHsPgIZ?usp=sharing
386 RC3-2 support models.
GT-AX11000
RT-AX92U
RT-AX88U
RT-AX82U
RT-AX58U
RT-AX56U
RT-AX55
TUF-AX5400
TUF-AX3000
ZenWiFi ET8
ZenWiFi XT8
ZenWiFi XD6
10/27 update
Add RT-AX86U and RT-AX68U in the same share link.
11/4 update
Add ZenWiFi XD4 in the same share link.
Quan
Hello,
On my Asus XT-8 client, I still have the message connection failed, IP/Routing client.
On my Asus OpenVPN server, it shows connected:
Why does the Asus XT-8 client show connection failed?
Thank you.
afool622
Just updated both my xt8 nodes through the Android app. So far so good
octopus
Part of the Furniture
Hi All,
GT-AX11000
RT-AX92U
RT-AX88U
RT-AX82U
RT-AX58U
RT-AX56U
RT-AX55
TUF-AX5400
TUF-AX3000
ZenWiFi ET8
ZenWiFi XT8
ZenWiFi XD6
No RT-AX86U?
RadarJammer
The ZenWifi Mini XD4 seems to be forgotten. Nothing since May.
S.claus
I setup Cloudflare Warp (it shows connected) but it doesn't allow any traffic. Below is my config (keys redacted) so I am curious if this is a configuration error or is it on ASUS side ?
afool622
so it turns out my 2nd node didn't update correctly and required a manual update.
I also found the speed test in the android app wasn't working correctly (inflated my speeds by 4x)
afool622
Speedtest isn't working too well.
My configured VPN connections don't seem to be working right either, but I will need to dig in a bit.
However, it looks like speeds have bumped up a bit for me so thats a plus
afool622
Looks like vpn isn't working right (after a reboot). Even though I configured it for a few devices, all my traffic is going through the vpn. I might try reconfiguring the vpn to see if that helps. Speedtest still broken
nocer
Uploaded over 42095 a couple of hours ago, so far so good except vpn thingy as reported above. Radio status is healthy, backhaul keeps as high as 3.1GHz, no obvious lags, no Internet glitches...I will keep running this firmware for the time being, until further build is available.
Quan
How do I check radio status?
rage77
I'm beginning to think maybe my recently bought AX86U wasn't as future proof as I thought.
