I bought a AX88U to use with OpenVPN due to the fact that it's CPU should support hardware acceleration for the encryption.
I got this information from here: https://www.privateinternetaccess.com/blog/hardware-acceleration-is-here-for-routers-using-openvpn/
However, when using the OpenVPN client my speeds are still limited and I see one core at 100%, suggesting that it is not working. The link above for example shows a download of 160mbit with 1% CPU usage with working hardware acceleration.
In the image below you can view my VPN configuration. I'm on 384.19.
Thanks for any help.
