Did ASUS Router Support USB Modem MF920W+ ? "Your ISP's DHCP does not function properly"
XuiKoh
Was having a usb modem with ZTE model MF920W+
and trying to connect with my asus router Rt-AC3200, for usb modem tendering
But was facing an issue with error messages " Your ISP's DHCP does not function properly"
seeking for help.
seeking for help.
Did you enable USB mode under USB Application > 3G/4G?
Yeah I did enable that
Was having another device with older model that Working fine
But while I swap to the latest model which support 4g ,LTE then facing this issue
The model was not on the list
I was having this same error while tethering my Nexus 5. I am getting out to the internet fine, but I am thinking it is related to the WAN IP that is assigned to the router being a private IP, so you are effectively double nat'ed.
On mine, the error did go away and the device connected fine. Maybe your error is staying though, which could be a different issue.
