Dual WAN Gateway Access
veroikeb
I’m using Dual WAN configuration on an Asus router. The router gateway is 192.168.50.1 while gateway of router that serves secondary WAN is 192.168.8.1
Can I access my secondary WAN router (192.168.8.1) through my main router (192.168.50.1)?
Thanks for reading.
I tried. Couldn’t access it. For reference, the main router LAN IP is 192.168.50.1 with subnet mask of 255.255.255.0
Yup. That sounds about right. When I disconnected Primary WAN to mimick ISP disruption, that’s when I was able to access secondary WAN router’s gateway. I gather there’s no way around this limitation, right?
Hello, what's ur router OS?
I use OpenWRT and am able to do it, even on the modem that's on bridge mode.
On OpenWRT, we must create an interface that redirects requests to the modem, so that the router knows where to route it, because it doesn't know automatically. Once the interface is created, it works fine.
Note that it works because the modem, even on bridge mode, provide an IP addr on its port. This makes it directly (on its POV) reachable from the LAN. It doesn't have amInternet addr because it's the router who's making the PPPoE connection and receiving IPv4 and IPv6 addresses, so the modem is unable to reach Internet, but it's reaclable from LAN.
