I am searching for a dual WAN router, which will run on a 100/5 mbit and a 50/10 mbit connection. Further it needs VPN, Load Balancing.
Therefore I saw two routers which would fill my requirements.
- Draytek Vigor 3200
- Netgear SVX5308
Which one you can recommend. And what are the pro and cons of these to models. Does anybody has tested the WAN and VPN passthrough of the 3200?
Thanks for you help!!
J L
- Netgear SVX5308
J L
