Force switch back to Primary WAN
Is it possible to force switch back to primary WAN from secondary WAN manually?
You are going to have to explain your setup in more detail and what you are trying to accomplish before someone can offer you a possible solution. A diagram of your network would be helpful.
Normally switches have nothing to do with the WAN as they are installed behind a router and their function is to switch traffic on the LAN.
