Good wireless router for 120.00
NbaFan21
I am looking for a reliable no dropouts or reset router. I want to spend 120.00 is the dlink 1750 smart beam like this? Thanks
Personally, I've been burned enough by D-Link products that, while some may be OK. Why risk it.
If you just want a mainstream 11n (not bleeding edge 11ac) router - you can spend $40 to $80. ASUS RT-N12/D1 - I use that. Just fine for the iPad, iPhone, Android phone, Android tablet, and 3 desktop wired PCs here. ISP is 35/5, cable modem.
Or get the next newer equivalent to that ASUS, above.
At that price range I recommend TP-Link. The C7 v2 is a bargain now
I'm using the TP-Link C7 v2 right now as well and it's been great. I moved from the first N version of the Apple Airport.
