FlexQoS Help with FlexQoS
lefteris.lydios
Hi.
Can someone pls help me with FlexQoS percentages?
What do they mean and how can I prioritize something (gaming for example) over something else (Media streaming for example) ?
How I am sure my packages are falling in the class that they are supposed to be?
pic is random
thx
The default settings should be a pretty good starting point and i left them at default. However, for gaming under upload minimum you can take 5% from W-F-H (make it 15%) and bring up gaming to 20%. You can also take another 5% from "Others" and adjust gaming to 25%. I doubt these minor changes will make any changes since gaming doesn't use too much bandwidth. You can play with minimum % as long they all add up to 100%. Like i said, default should be gtg on most setups.
