How to check the cpu temperature in the LTS Fork ?
Nite01
I have installed the latest LTS Fork firmware on my RT-AC66U.
In the administration\temperatures page I only see the radio temperatures, if I recall correctly in the past there used to be also the cpu temperature. Or am I mistaken ?
Tech9
Part of the Furniture
This router doesn't have CPU temp probe, as far as I know. I have one MIPS AC66U and I've never seen CPU temp reported.
Tech9
I just use one of these
CPU temp is higher than heatsink temp. This is the main issue with AC86U routers - poor heat transfer. With heatsink at 60C the CPU may be at 90C.
Tech9
What, the region specific AC86U ?
Every AC86U. This router won't survive Asus claimed 0-40C operating ambient temperature. Read more here:
Jumpstarter
I guess We are doomed with these standard temps.
Tech9
Some are not as lucky as you. Read the entire thread. This router has other common issues too.
