In Asuswrt, how to display the log timestamp with nano seconds?
pseu_asus
Seems the following command does not work in my Asus router. Does anybody know how to display the timestamp in nano seconds?
maven@PSU-AX56U-1:/jffs/scripts# date +"%T.%N"
14:45:20.%N
maven@PSU-AX56U-1:/jffs/scripts# date +"%T.%3N"
14:50:21.%3N
I believe the router has this capability as I saw Ookla speedtest-cli error log in this format on this router:
[2023-06-17 03:03:18.835] [error] Configuration - Timeout was reached (TimeoutException)
[2023-06-17 03:03:18.845] [error] Configuration - Cannot retrieve configuration document (0)
[2023-06-17 03:03:18.849] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
14:45:20.%N
14:50:21.%3N
The BusyBox version of date on Asus routers
BusyBox v1.25.1 (2023-05-07 12:35:01 EDT) multi-call binary.
Usage: date [OPTIONS] [+FMT] [TIME]
Display time (using +FMT), or set time
    [-s,--set] TIME    Set time to TIME
    -u,--utc    Work in UTC (don't convert to local time)
    -R,--rfc-2822    Output RFC-2822 compliant date string
    -I[SPEC]    Output ISO-8601 compliant date string
            SPEC='date' (default) for date only,
            'hours', 'minutes', or 'seconds' for date and
            time to the indicated precision
    -r,--reference FILE    Display last modification time of FILE
    -d,--date TIME    Display TIME, not 'now'
    -D FMT        Use FMT for -d TIME conversion
Recognized TIME formats:
    hh:mm[:ss]
    [YYYY.]MM.DD-hh:mm[:ss]
    YYYY-MM-DD hh:mm[:ss]
    [[[[[YY]YY]MM]DD]hh]mm[.ss]
    'date TIME' form accepts MMDDhhmm[[YY]YY][.ss] instead
doesn't support the %N switch.
You will need to install the Entware version coreutils-date
date (GNU coreutils) 9.3
Copyright (C) 2023 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <https://gnu.org/licenses/gpl.html>.
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Written by David MacKenzie.
FORMAT controls the output.  Interpreted sequences are:
  %%   a literal %
  %a   locale's abbreviated weekday name (e.g., Sun)
  %A   locale's full weekday name (e.g., Sunday)
  %b   locale's abbreviated month name (e.g., Jan)
  %B   locale's full month name (e.g., January)
  %c   locale's date and time (e.g., Thu Mar  3 23:05:25 2005)
  %C   century; like %Y, except omit last two digits (e.g., 20)
  %d   day of month (e.g., 01)
  %D   date; same as %m/%d/%y
  %e   day of month, space padded; same as %_d
  %F   full date; like %+4Y-%m-%d
  %g   last two digits of year of ISO week number (see %G)
  %G   year of ISO week number (see %V); normally useful only with %V
  %h   same as %b
  %H   hour (00..23)
  %I   hour (01..12)
  %j   day of year (001..366)
  %k   hour, space padded ( 0..23); same as %_H
  %l   hour, space padded ( 1..12); same as %_I
  %m   month (01..12)
  %M   minute (00..59)
  %n   a newline
  %N   nanoseconds (000000000..999999999)
  %p   locale's equivalent of either AM or PM; blank if not known
  %P   like %p, but lower case
  %q   quarter of year (1..4)
  %r   locale's 12-hour clock time (e.g., 11:11:04 PM)
  %R   24-hour hour and minute; same as %H:%M
  %s   seconds since the Epoch (1970-01-01 00:00 UTC)
  %S   second (00..60)
  %t   a tab
  %T   time; same as %H:%M:%S
  %u   day of week (1..7); 1 is Monday
  %U   week number of year, with Sunday as first day of week (00..53)
  %V   ISO week number, with Monday as first day of week (01..53)
  %w   day of week (0..6); 0 is Sunday
  %W   week number of year, with Monday as first day of week (00..53)
  %x   locale's date representation (e.g., 12/31/99)
  %X   locale's time representation (e.g., 23:13:48)
  %y   last two digits of year (00..99)
  %Y   year
  %z   +hhmm numeric time zone (e.g., -0400)
  %:z  +hh:mm numeric time zone (e.g., -04:00)
  %::z  +hh:mm:ss numeric time zone (e.g., -04:00:00)
  %:::z  numeric time zone with : to necessary precision (e.g., -04, +05:30)
  %Z   alphabetic time zone abbreviation (e.g., EDT)
e.g.
/opt/bin/date +"%T.%N"
08:52:32.082901975
What you see in the log are milliseconds, not nanoseconds. Nanoseconds are the range of Gigahertz clocked processors.
Thanks,@Martineau. May I know how to install Entware version coreutils-date?
Install Entware from amtm (You will need a USB flash drive attached to the router)
amtm
then install the Entware date utility
opkg install coreutils-date
