Unconnected
Topology
Two ASUS routers:
IPv6 Configuration
Disclaimer: please excuse my ignorance. It's been many years since I've had a networking class and I haven't kept up with any of this -- some of you are true geniuses!
Two ASUS routers:
- 1st plugged into a modem (w/ WAN aggregation)
- 2nd plugged into the first router
- both are in router mode and not set up as an AP
IPv6 Configuration
- The first router has IPv6 set to Native and is able to obtain an address from the ISP. A test at test-ipv6.com shows confirmation.
- The second router, w/ the same Native settings does not have a successful test-ipv6.com result and the IPv6 prefix does not appear on the router's settings.
- When I set the connection type on the second router to Passthrough then test-ipv6.com has a successful response.
Question(s)- Is Passthrough a bad idea? For some reason I thought it was discouraged because it might bypass firewalls and present more security concerns, though I'm still reading up on what it does and its implications.
- If this does bypass the client-router's firewall, does it still honor the host-router's firewall settings?
- Given the router-to-router connection, is Native on the client-router possible and perhaps misconfigured?
- I've disabled NAT/PPPoE and WAN/UPnP, would either affect this? -- I've attempted variations of enabling either and both, but haven't had much success.
- Should I disable DHCP-PD on the client-router? (and manually set the IPv6 Address and Prefix length)
- What is the general issue here? I don't understand the concept of what is happening. The computer on the sub-LAN has an IPv6 address, but as the traffic is exiting the router, is it dropped? Why does IPv4 step in and route correctly?
