1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
Is there a way to open a port via the WebUI for a server running on the router itself?
Discussion in 'Asuswrt-Merlin' started by Quenlinlom, Feb 21, 2020.
  1. Quenlinlom
    Quenlinlom New Around Here
    Feb 21, 2020
    1
    I've installed Tor via Entware and I wish to run it as a non-exit relay. For that I need to open ports 9001 and 9030.
    I've been fiddling with the Port Forwarding page with no luck so far. For the "internal IP" I've tried both 192.168.1.1 and 127.0.0.1 but to no avail. The inbound packets either get dropped or get routed to nowhere.
    A similar setup would work if I run Tor on my PC instead of the router, and then forward to my PC's IP, but I really want to do all that on the router itself. Is it possible? Do I have to do some manual iptables fiddling instead of using the WebUI?
    [​IMG]
  2. Zirescu
    Zirescu Very Senior Member
    Jul 16, 2013
    731
    Kelowna, BC
