Hi all
I'm looking for a substitute for my 5 years old AC56U. I had no big problems so far with it, but I now begin to see it's limit with my increasing (30 devices so far, 25 static DHCP entries, 5 port forwardings,2 guest networks, AB Solution ad-blocker, NTP server,VLANs) home network. I really love it's interface (and I'm using Merlin firmware since the beginning) so I'd like to buy another one from Asus, possibly supported by Merlin.
I don't have any AX device so far, but I plan to keep my new router for at least 5 years. I do need to have VLANs, due to my network configuration: at the moment WAN is trunked with VLAN2 untagged and VLAN1 tagged. I make a sporadic use of OpenVPN and I will connect a USB HD to the USB3 port for network camera recordings. My VDSL is managed by an AVM Fritz!Box7530 and is a 200/20. My budget is around 200€.
I found that both RT-AC86U (223€) and RT-AX92U (210€) could suit my needs:
The 86U would be the choice, but is now more expensive than the probably more future-proof 92U; it seems to have a very good network coverage and its supported by Merlin.
The 92U is cheaper (now) but seems that the wireless performance on the N/AC are the same as my old 56u, and most of the "6100" are in the 5 only Ghz AX band. I'm not sure about its network coverage and has no Merlin support so far.
Can anybody advise me on them? Is there a way to have VLANs working with stock firmware in case I would buy the 92U (I mean, without using another VLAN capable switch and may be using IPTV feature?)
Regards
Giuseppe
Regards
Giuseppe
