Low upload speeds from AXE11000 ET 12 Node
CapedCrusader117
Hi there,
I am currently having an issue with low upload speeds from my AXE11000 ET 12 node. The ET12 node is connected to the ET12 router via the 6ghz dedicated backhaul. Here as some more details
Connection Quality: Great
RSSI = -63dBm
Firmware Version: 3.0.0.4.388_23013
Backhaul Connection Priority: 6Ghz first
6Ghz SSID: Hidden
When the Internet Speed test is done for the ET12 Router, it shows the symmetrical 1Gbps up, 1Gbps down speeds. However, when i do the same test on my PC that is connected by ethernet to the ET12 Node, i get close to the 1Gbps download speed but somewhere less than 210Mbps in upload speeds. Any potential solutions would be helpful!
Does a wireless client (laptop) show the same speeds when connected to the main router and the node?
Just ran speedtest on my Galaxy S21 and got 830Mbps down, 191 Mbps up from the Node. Ran it again near to the main router and got 800Mbps down 560 Mbps up.
A handheld device is primarily into power savings. Try a laptop in Performance mode and/or plugged into AC power.
Funnily enough, my laptop gave worse download and upload speeds than my S21 did (and yes it was on performance power plan with A/C plugged in). In any event, the symmetrical 1Gbps was not being achieved, with download speed hovering around 600 Mbps and upload speed hovering around 170 Mbps.
What CPU does it have? What browser were you using? What speedtests are you trying? What wireless adaptor card does it have?
