All of my wall jacks look like they terminate at the outside cable box, but none of them are connected except for my cable internet line.
My cable provideder is TWC. Will they come out and re-connect the destination jack I want to run MOCA over? If so, how should I explain what work I want them to do? I basically want a single MOCA connection from the cable moden to my my living room jack.
Right now, the street input goes through a single 1000ghz 6db bidirection coupler tap. This coupler/splitter has 1 input and 2 outputs, where one output is labeled "TAP 6dB". The internet coax is connected to the TAP output, and the 2nd output is disconnected.
Will MOCA be able to run through this by adding the 2nd line I need to the currently disconnected output? I can post a picture if that helps.
