I am trying to mount a drive array (Mediasonic Probox with 2 HDDs) connected by USB to a N66U on a PCH Networked media tank without success.
I setup Samba and NFS share options on the N66U and can browse to folders on the Probox from my windows PC as well as from the PCH.
However when I telnet into the Popcornhour NMT and run the following mount commands the session either hangs or I get permission denied.
/bin/mount -t nfs 192.168.2.3:/dev/sda2 "/share/Mounts/vdo11" -o soft,lock
/bin/mount -t cifs //192.168.2.3/dev/sda2 "/share/Mounts/vdo11" -o username=admin/password=****
192.168.2.3 is the IP of the N66U.
The above command syntax works fine to mount shares from multiple NAS devices on the PCH.
Could someone help me sort out the mount commands above please.
Following is the df -h output
Filesystem Size Used Available Use% Mounted on
/dev/root 24.3M 24.3M 0 100% /
tmpfs 117.1M 2.2M 114.8M 2% /tmp
devfs 117.1M 0 117.1M 0% /dev
/dev/sda2 2.7T 367.1G 2.4T 13% /tmp/mnt/vdo11
/dev/sdc1 931.5G 464.0M 931.1G 0% /tmp/mnt/vdo12
Thanks, M
Thanks, M
